Made some improvements to my 1995 Passport.
Postby rbarrios » Wed Jan 11, 2017 1:10 pm
I needed an SUV for use on my dads ranch house out in Mexico.
His place is up in the hills- 8 miles away from town.
Dirt and rocks.
My father in law had this 95 Passport. Plated in Mexico and California.
He used it to travel back and forth.
It recently had a tune up and passed California SMOG.
Also had a new trans put in.
So I bought it from him.
In July when I drove it- I noticed a few things.
Very bouncy ride. Shocks worn.
Missing H on grille.
Missing wheel caps.
Tweaked rear door and bumper.
Mud all over the sides.
Speedometer/odometer/trip meter not working.
So with 6 month time- I went on ebay and searched.
Bought
H logo,
used cluster
new old stock heavy duty front and rear schocks,
used OEM mud flaps
used wheel caps
used but repainted bumper brackets.
father in law- had a used rear door in the correct color
24 new wheel lug nuts with the proper washers for the caps (I had the post requesting info the proper lug nuts).
So I installed it all. I also changed out the shifter bulb- burned out, overhead lamp also burned out, and 1 bulb on the cluster was burned out.
The vehicle now rides much better.
Used to be- on a speed bump- the vehicle would bounce 3-4 times... now-- 1 bounce.
Unfortunately the H did not fit--- turns out there is an ISUZU grille on the honda.
on a rural road.
the ebay caps--- note the dirty side- and the cleaned shiny side on one cap
before caps
after caps.
old rear mud flaps (dont know if the old ones were OEM?)- compared with ebay find.
rbarrios
Re: Made some improvements to my 1995 Passport.
Postby rbarrios » Wed Jan 11, 2017 1:11 pm
old cluster with 150,xxx
new ebay cluster with 199,xxx. No idea how many miles on engine.. I just want to know how fast im going and miles traveled for oil changes.
the old door and new.
rbarrios
note the marks on the old one-- hammered back to be sort of straight
I did not have jack stands to replace the rear shocks. I didnt want to get under the vehicle with only a jack----so I drove into town- to a small shop to replace the rears.
cost- $100 pesos... thats $5 USD!
The vehicle hosed down to get rid of all the dust.
Somewhere in its life- it was hit on that rear quarter. note the paint color change/the brackets/the tweaked rear door.
Rural area--- putting the vehicle to work.
so we need to take these tanks into town to refill.
the endcap for the passenger side rear bumper--- is on its way.. should be installed soon.....
rbarrios
Postby PPCLI-JIM » Wed Jan 11, 2017 2:30 pm
Note to you , i have a 97 rodeo and my fuel filler nozzle rusted right off, when your under there looking up check the condition of it and if its possible power clean it and give it a coat of some sort of protector either a rockgaurd or paint ... save you some hassle in the future. looks good hey if you stil have that old bracket flopping around could you take a pic of it or draw it out with the dimensions as i want to start fabbing my own bumper. the brackets are always the trickiest part. Thank you
Its a small amount of fuel , but it's a whole lot of walking..Note from my Dad
97 Rodeo AKA the Pavement Princess.Maybe ill just keep it fairly stock but more capable ... viewtopic.php?f=15&t=86504 My 88 Trooper II viewtopic.php?f=15&t=85416
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority and rabidly promoted by an unscrupulous mainstream media, which hold forth the proposition that it is entirely possible to pick up a turd by the clean end.
PPCLI-JIM
Has thanked: 29 times
Have thanks: 10 times
Postby rbarrios » Wed Jan 11, 2017 2:45 pm
well im back in the USA.
Next time Ill look at the filler door.
thought based on the chassis being rust free after 22 yrs.... its a long shot the door is rusting.
brackets.... I think we threw em out.
For this post the author rbarrios was thanked by:
PPCLI-JIM
rbarrios
Postby PPCLI-JIM » Wed Jan 11, 2017 3:45 pm
its not the door its the filler neck itself . thanks for the quick reply i guess ill have to go lay in the snow and drop the bumper so i can plan my build ... sigh its just soooooooo cold and snowy
PPCLI-JIM
Postby rbarrios » Wed Jan 11, 2017 3:53 pm
ahhh the filler neck.
Will have to check it out.
rbarrios
