Moab Zu Zoo 2017
Use this forum to discuss Trail Rides, Wrench-A-Thons and other meetings
Moab Zu Zoo 2017
Postby AirAmigo » Fri Nov 18, 2016 12:10 pm
What are our Moab dates for 2017?
Thanks,
Keith Johnson
Prosser, WA
"AirAmigo!" 1994 Isuzu Amigo XS 4x4
MODS: Front SAS with 1985 Toyota Pickup Axle with 5.29's and a ARB locker, Rear SAS with 1994 Toyota Pickup Axle with 5.29's and a ARB locker, front disk brake conversion kit, rear disk brake conversion kit, WARN hubs, crossover steering, RANCHO 9000 shocks, Tera Low's in the T-case for 3:1, custom front winch bumper with IPF 130W off-road lights, rock guard rails, Warn HS9500 winch, Isuzu 2.6L engine .30 overbore custom build, and 33.x13.50x17 Super Swamper IROK tires.
AirAmigo
Re: Moab Zu Zoo 2017
Postby BigSwede » Fri Nov 18, 2016 3:01 pm
Traditionally it ends on the 3rd Saturday in May, so May 20th in 2017.
BigSwede
Has thanked: 14 times
Have thanks: 244 times
Postby AirAmigo » Fri Nov 18, 2016 5:45 pm
Thanks Swede! I'll be there for the whole event. I'll be off work from May 12 thru May 22.
Keith Johnson
Prosser, WA
AirAmigo
Postby outofrshell » Thu Dec 01, 2016 1:24 am
any one interested in the Rimrocker Trail before Moab. My grand daughter and are going to try the week before Moab hope there is some interest. Dave
1989 Trooper 2.8/ 3.2 built V6, 5speed
Revolution gears
ARB Rear locker
ARB Front locker
SWAY-AWAY HD TORSION BARS
Self made Longer shackles
1998 Trooper front disc brakes and front seats
Self made HD Tie rods
Self made bumpers and grill guard w/ KC & Hella lights
Self made sliders
Waren VRS 8000 winch set up to use at either end of Trooper
Custom made cargo box w/ full length roll out drawers
31 X 10.50 X 15 Cooper STT Pro on Cragar black steel wheels
outofrshell
Have thanks: 38 times
Postby BigSwede » Thu Dec 01, 2016 2:19 pm
Might be interested, too soon to tell. How long are you thinking that trail will take Montrose to Moab?
BTW I am thinking of coming to Wyoming in August for the solar eclipse on the 21st...which also happens to be my birthday (just a coincidence I'm sure).
BigSwede
Postby outofrshell » Fri Dec 02, 2016 10:29 pm
The info I have looked at says says it can be run in 2 days but I would like to give it 3 days and take it a little slower to make it more enjoyable. I guess it would also depend on trail condition and what kind of country you were in. Tabby's Trooper is completely stock so that could slow things a little although what I saw in Co. she is a good driver. Dave
Revolution gears
ARB Rear locker
ARB Front locker
Self made sliders
outofrshell
Postby BigSwede » Sat Dec 03, 2016 2:01 am
Not sure if I have enough time to do that, but we'll see.
BigSwede
Postby hessmess » Fri Dec 30, 2016 3:14 pm
Subscribed, Trooper is up and running this year. Now to get the lift done and sliders that have been in boxes for 3 years now.
88 Trooper (recycled)
viewtopic.php?f=15&t=81567
viewtopic.php?t=55081
hessmess
Has thanked: 7 times
Have thanks: 130 times
Return to General Events & Gatherings
