Spring Beasley Knob - April 14th (Good Friday)
Use this forum to discuss Trail Rides, Wrench-A-Thons and other meetings
Postby egagnon086 » Mon Mar 27, 2017 11:57 am
Come one, Come all, Test your skills. Meet up 8:30 AM in Dahlonega near 400.
10.6 miles of trails ranging from difficult to most difficult.
Come and enjoy the cool weather of the GA mountains during the summer.
Trail fee $5 bucks per day.
Please insure you have the proper safety/recovery gear for/on your vehicle and yourself/passengers.
My plan is doing this on a Friday 14th and hitting as much of the trails as we can. If it gets to busy we can head to several other "good" trails.
Beasley, Then maybe head down some "forest roads".
FS-USDA info: http://www.fs.usda.gov/recarea/conf/rec ... 3&actid=93
egagnon086
Has thanked: 53 times
Have thanks: 92 times
Re: Spring Beasley Knob - April 15 or 16
Postby TPR10inchIFS » Mon Mar 27, 2017 3:47 pm
My brother said Sunday would work best for him and even that's not a guarantee because he opening a new store that weekend. Either one works for me.
DONE: 02 Isuzu Trooper Limited, 10" custom lift, 7"suspension, 3"body. Calmini torsion bars indexed, Rusty's coil overs with pucks, fitted Rancho 5000 shocks, widened/welded brackets for shocks, extended front sway bar links, Independent4x extended brake lines, Independent4x steering extension, Independent4x HD tie rods with custom spindle/hub assembly insert for full +- travel, custom shortened cv axles and custom welded front diff drop brackets for full +- travel, upper and lower ball joint shims/wedges with Independent4x ball joins swap spacers for full +- travel, extended body safety hooks, extended e-brake brackets, extended shift linkage, extended transfer case shifter, 1.5" front wheel spacers, rebuilt engine, rebuilt trans withe the "playing with fire" front PWM pump swap, 300-400rpm lower stall torque converter, external trans cooler, Super Winch manual locking hubs, ARB front bumper with angled end caps, driving light inserts, and mounted PIAAS, front/rear custom 3" bumper brackets, Surco roof rack on custom Bosch extruded aluminum sliding frame to cover or expose sunroof, custom fog light wiring harness to allow roof rack travel, front fogs, side "camping" fogs and rear reverse fogs on rack, cold air intake, thrush high flow muffler, rodeo head rests front and rear, oh *!$!@*! grab handles drivers side, custom sound with 6" speakers in rear and two 12" subs, six 17" Moto Metal wheels with BFG TA KO 315s (35") tires
TO DO: Warn Winch and reinforce bumper brackets, custom rear bumper, Ausie lockers, rear jump seat, rear oh *!$!@*! handles left and right. tint windows, 1/4" - 1/2" rear wheel spacers, upgrade brakes to dual pistons and slotted, custom rock sliders, all new poly bushings, convert all lights to led.
MIGHT DO: Snorkel, air shocks with onboard compressor, roof rack tent, dual alternators and battery, cb, front Reese hitch, winch Reese mount for using front or rear.
TPR10inchIFS
Re: Spring Beasley Knob - April 14 or 15th
Postby egagnon086 » Tue Mar 28, 2017 7:51 am
Just was reminded by my better half that the 16th is easter sunday. So that is a no go.
I also just found out I have the day off on Friday the 14th, so that may be a great day to get out and ride. Can anyone make it on April 14th?
egagnon086
Postby reran » Tue Mar 28, 2017 3:20 pm
I wouldn't mind heading up there sometime soon, unfortunately, that's less than two weeks before Uwharrie, so it's a no go for me. Also, although, a little time at Beasley is a good thing, I'd prefer to spend a majority of the time exploring the forest service roads. So a weekend would be better I think.
"As slowly as possible, as fast as necessary."
"Do what you can, with what you have, where you are." Theodore Roosevelt
89 Trooper, 2.6L Turbo, AW 30-80LE
90 Spacecab LS 4wd, 2.6, 5spd
94 Trooper SE, 3.2 DOHC
Image Image
reran
Has thanked: 8 times
Have thanks: 24 times
Postby egagnon086 » Tue Mar 28, 2017 4:56 pm
I'll definitely be setting up another man run after uwharrie maybe in late May after I get me Revo gears in.
egagnon086
Postby Chris-6mgte » Tue Mar 28, 2017 8:04 pm
I could make it out on Friday, April 14 or Saturday the 15th.
'88 Trooper 294k, (the Sandbox)
Jerry cam; fresh AMC head; custom fan shroud and electric fans; HD torsion bars and rear Add-a-Leaf; rebuilt entire front end joints/ bushings, links etc..;
Autometer gauges; custom winch bumper and roof rack. Uniden 520XL CB.
Chris-6mgte
Re: Spring Beasley Knob - April 14th (Good Friday)
Postby egagnon086 » Thu Apr 06, 2017 2:41 pm
So its been settled, Friday the 14th. Early-ish meet up.
If you can't make it this time, I'm going to try and schedule something in late May or June, see if we can have a little camp out weekend or something like that.
Hope to see you there, PM me if you have any questions.
egagnon086
Postby Georgia159.com » Thu Apr 06, 2017 4:00 pm
Hey, good to see some other Georgia Isuzu folks on here!
Wished I could, but have to work that weekend. :(
199? Rodeo (ISO of my next project truck- being picky)
1997 Rodeo 2WD 3.2 V6 Auto (4-1-13 - Purchased for $580. Best deal ever. My DD.)
1994 Rodeo LS 2WD 3.2 V6 Auto (2015 - Bought for Parts, but still running! The Backup.)
1997 Honda Passport 2WD 3.2 V6 Auto (2015 - Parts donor - PM if you need something)
Georgia159.com
Has thanked: 17 times
Postby egagnon086 » Tue Apr 18, 2017 9:43 am
So this was a good time for the GA Zu Cru, we had 3 Zus and a 2nd gen Jeep Grand Cherokee with us. They have done some great trail maintenance this year and opened a lot of the closed trails, They also bypassed the super dangerous part near the top, No loss there. It started as a great dry day as the pictures will show, Then when we reached the top of the mtn it started pouring rain. It made for an interesting ride out. For all those that couldn't make it, Shoot me some times that work for you and Ill try and organize another outing this summer and again in the fall.
To commence with Epic picture post. I will post links to the Youtube vids:
There were some "exciting" parts
A lot of steep muddy hilss, were getting the truck hot, like really hot: We had to do some impromt trial fixes
egagnon086
Postby egagnon086 » Tue Apr 18, 2017 9:48 am
More epic pics:
Lots of rocky bits like this
Made it on top just in time to catch a downpour
egagnon086
Postby egagnon086 » Tue Apr 18, 2017 9:53 am
I did take acouple neat Panoramic pics also:
Pit stop at the top of the Mtn:
The GA ZU CRU, Riding in the storm...
We will have to do this again, You guys need to ride on Beasley knob to see how much fun can be had.
egagnon086
Return to General Events & Gatherings
