98 passport map lights
Postby Det0x » Tue Jan 24, 2017 11:07 pm
I have a 98 Honda Passport that I am slowly sinking money into, and was looking at some of the LED upgrades, and see the mention of map lights. I have no map lights. I see on ebay replacement rear view mirrors with 2 map lights, was this an option? I think mine is the LX, with no fog lights and the spare mount on bottom. If so, is the wiring present in mine for factory map lights in the mirror? Is the factory fog light wiring there to tap into?
Thanks for any input.
Det0x
Re: 98 passport map lights
Postby OlRob65 » Tue Mar 28, 2017 4:49 pm
The fog light wiring is all there in my 2000 Rodeo. The wiring for the switch is taped to the mail wiring harness behind the plate where the cruise control/4x4/blank switch is housed. You will need a relay and a switch too. I found out that the rear defroster switch will work in place of the oem fog light switch. I don't know if will be able to tap into them for your map light idea as they are just long enough to reach the plate where the switch lives.
Hope this helps.
OlRob65
Has thanked: 4 times
Return to Audio & Electronics
