'01 Rodeo with dim cluster lights
Postby Dextreme » Tue Jan 10, 2017 3:10 pm
I bought my daughter an '01 Rodeo a few months ago and trying to research why the dashboard cluster lights are so dim with the dimmer set to max. The cluster seems like it is half the brightness that it should be. (There doesn't appear to be any bulbs burnt out. ) Are there brighter bulbs I can put in? Or is it possibly an issue with the dimmer?
Note: I know some may suggest LEDs and I have them in my other vehicle (Wrangler)...love them, but ya can't dim them down. Want to keep these dim-able for her.
Thanks for any suggestions!
Dextreme
Re: '01 Rodeo with dim cluster lights
Postby BigSwede » Tue Jan 10, 2017 5:03 pm
Don't know if the Rodeo is the same way, but on my Trooper the dash lights are on the same circuit as the tail lights. So if you have a wonky trailer light converter it can affect the dash lights. Worth checking anyway.
BigSwede
Has thanked: 14 times
Have thanks: 249 times
Postby Dextreme » Tue Jan 10, 2017 5:52 pm
BigSwede wrote:Don't know if the Rodeo is the same way, but on my Trooper the dash lights are on the same circuit as the tail lights. So if you have a wonky trailer light converter it can affect the dash lights. Worth checking anyway.
That might be a good clue because a week ago I hooked up a small trailer (using the 7pin) to move it out of the driveway, and noticed the trailer lights didn't work on the trailer. I will check out the wiring.
Dextreme
Postby totten » Mon Jan 16, 2017 6:20 pm
May not be grounded at trailer wiring.
totten
Have thanks: 78 times
Postby QuantumRift » Sun Jan 22, 2017 3:49 pm
This is prob a bad ground issue. Corrosion or poor ground can result in an additional resistance (voltage drop), and cause less than 12V going thru the wiring to ground. Check the grounds on the circuits and any additional wiring you may have added.
"If Opportunity knocks and he's not at home, Opportunity waits."
"Find out what it is in life that you don't do well, then don't do that thing."
1990 Isuzu LS SpaceCab 4x4 (Japanese-built, September 1989)
224,000 miles.
K&N Air Filter
2.6 L 4ZE1 engine, 5-spd manual
Monroe Sensa-track Load Adjusting Shocks (rear)
Monroe OE Spectrum Shocks (front)
MagnaFlow Muffler & Cat Converter
Akebono ProACT Ultra-Premium Ceramic Brake Pads (front)
Wagner Thermoquiet Ceramic Brake Pads (rear)
Owned since 15 miles. Bought new Honolulu, HI in Oct '89.
Original sticker price: $15,000.
QuantumRift
Has thanked: 23 times
Have thanks: 99 times
Return to Audio & Electronics
