Axiom GPS sensor
Axiom GPS sensor
Postby haruspex84 » Mon Dec 26, 2016 8:08 pm
The clock and compass on my 2002 axiom no longer work. I believe a faulty GPS sensor is to blame. Does anybody have a fix for this since it's basically impossible to track down Isuzu parts these days?
haruspex84
Has thanked: 7 times
Re: Axiom GPS sensor
Postby ofg » Sun Jan 01, 2017 7:03 pm
First, check as many chassis grounds as you can find. Make sure they are tight and clean. Also, check the main ground cable from battery. If its badly corroded, then replace.
Now, is there anything else wrong with the car? Driving issues? Trans holding gears too long? Intermittent loss of power, and overall "tune" issues?
My gps clock is the same,, and I dont think its the gps sensor. Renewing grounds helped alot. I believe its related to the common abs sensor issue in the transfer case. Havent been able to replace mine yet,, but I have gone through everything else.
ofg
Has a Trail Truck
Has thanked: 2 times
Have thanks: 7 times
Return to Audio & Electronics
