F*** it's cold, help?
Postby jakparady » Tue Dec 13, 2016 8:03 pm
Okay hopefully my subject grabbed you. I have a few weird electrical issues since the cold set in in MN in the last 3 days.
SYMPTOMS
- Horn stopped working, but when I tap the button, the high beam indicator comes on briefly (WTF) yes I checked the wires to see if snow disconnected anything in the grill
- front window illumination on both sides stopped working, but back window illumination works (on the master switch. This issue was present before the negative temps and the 2 front lights come back occasionally)
- The 3rd dial on thermo-control panel is really dim. However, I noticed when I put 4-hi on the other day, it was fully lit like the temp and fan speed dials (WTF)
- Aftermarket Bully brand remote lock stopped working. I know the batteries in the FOB are good.
QUESTIONS:
- Is this a normal cold snap thing?
- Is there a short where the Bully aftermarket remote lock splices into the lock wires in the drivers kick panel junction?
- why in the world would the high beam indicator flash when i hit the horn.... dafuq?
- Dash battery gauge says normal 13-13.5 while running, but if there's a short after that wire, could I have low battery?
MINNESOTA
Anyone else here????
94 Trooper, Manual
LT265/70/R16 Hankook Dynapro ATM (295/75/16 Dynapro MT soon)
OME 3" Expedition Duty Springs/Coils (+ 2" Daystar Spacers)
3" indy4x BL
2 100w KC Hilites (front grill guard) I hit a chevy! oops...still kinda proud though.
6 55w Blazers (up top)
2 55w Hella Fogs (grill guard)
ARB safari Snorkel
Homemade Rear tube-style Bumper Guard
Homemade Roof Rack 6' x 4'
jakparady
Re: F*** it's cold, help?
Postby BigSwede » Tue Dec 13, 2016 11:55 pm
Weird random electrical issues are often the result of a bad ground. The juice is trying to find its way back to ground and going every which way. The question is which ground wire is the one... Do you have a shop manual?
I'm in Minnesota too, the Trooper is under a snowdrift.
For this post the author BigSwede was thanked by:
jakparady
BigSwede
Has thanked: 14 times
Have thanks: 246 times
Postby jakparady » Wed Dec 14, 2016 10:07 pm
I did have the haynes manual but gave it away with my amigo. Is there a section I can reference about major ground points..?
MINNESOTA
94 Trooper, Manual
3" indy4x BL
ARB safari Snorkel
jakparady
Postby BigSwede » Thu Dec 15, 2016 2:15 am
The shop manual for my 95 has an inch-thick electrical section. I don't think a Haynes will have enough detail to be helpful. You're welcome to have a look at mine if you want. There's little difference between a 94 and 95. I'm in the west metro Twin Cities.
BigSwede
Postby jakparady » Tue Dec 20, 2016 11:00 pm
So is that section just crazy full of diagrams? I can definitely find and clean all the ground points but do you think I can track down which wire is a compromised ground wire?
MINNESOTA
94 Trooper, Manual
3" indy4x BL
ARB safari Snorkel
jakparady
Postby BigSwede » Tue Dec 20, 2016 11:33 pm
I am no expert, but I have watched a technician with a schematic and a simple test light figure it out.
BigSwede
Return to Audio & Electronics
