$900 94 Rodeo alternator issue
Postby fantasoap » Thu Dec 08, 2016 12:53 am
Hello and thanks in advance... I'm inexperienced with electrical systems.
Patient facts:
1994 Isuzu Rodeo, 200,000 miles, 6 cylinder engine, 2wd, purchased by current owner for $900 in September 2015.
October 2016-After slamming my hood shut with needless force, I started the car and began driving, but I soon noticed that the dashboard voltmeter had dropped from its normal 13 volts to below 12 volts. I proceeded to hurry home before the battery died, as I assumed this meant that the alternator was no longer generating current.
On the way, as the voltmeter steadily dropped, several idiot lights came on (the brake warning light and two others which I don't remember). I continued driving.
About halfway home, I hit a pothole.
Eureka! The voltmeter jumped back to about 13 and the idiot lights all went out.
I did not investigate the matter further.
December 2016-Though I did not slam the hood again, the scenario repeated itself exactly, except that this time the battery drained down, the car stopped running, and I called a tow truck.
To me, it sounds like a loose wire, because of the jarring that initially caused the alternator to stop charging the battery, and the subsequent bump that seemed to fix the problem, but I am not sure about how to locate the broken connection. My dad suggested that the engine block ground strap might be loose, corroded, or severed, but I am not sure where it is located. I have been looking for an uninsulated, flat braided cable roughly 15 mm wide, but all have found is an insulated wire about 2 mm in diameter connecting the cylinder block to the sheetmetal on the North American passenger-side of the engine.
I really appreciate any ideas people have, and suggestions as to necessary tools and reference documents would be extremely useful. Thanks!
fantasoap
Re: $900 94 Rodeo alternator issue
Postby Carl747 » Thu Dec 08, 2016 2:13 pm
I had a problem with my Trooper that was not the same, but similar. When it was finally taken into the mechanic the problem was that a bad battery terminal was causing the battery to arc and lose charge. It sounds like you have a similar problem or a wiring problem. I would take it to Auto Zone or a similar place where they will test your alternator free of charge and see what they have to say before you take it to a mechanic.
Here is a more in depth explanation of the problem I had if you are interested:
http://www.planetisuzoo.com/viewtopic.php?f=7&t=95073
98 Trooper S. 230k miles, Dark Blue.
For this post the author Carl747 was thanked by:
fantasoap
Carl747
Has thanked: 4 times
Postby fantasoap » Sat Dec 10, 2016 5:46 am
Carl747 wrote:I had a problem with my Trooper that was not the same, but similar. When it was finally taken into the mechanic the problem was that a bad battery terminal was causing the battery to arc and lose charge. It sounds like you have a similar problem or a wiring problem. I would take it to Auto Zone or a similar place where they will test your alternator free of charge and see what they have to say before you take it to a mechanic.
Thanks for the advice!
fantasoap
Postby batvette » Sun Dec 11, 2016 9:32 am
Intermittent open circuits can be tough to diagnose. I would disconnect your negative battery cable and go over all the connections in your charge system starting at the alternator, then the underhood fuse box etc. If in doubt about that ground strap add another..you may want to do it by the book with a schematic.
1995 Passport V-6 2wd 5spd.
Solar powered ventilation & sound system w/custom kickpods and 15's:
http://s353.beta.photobucket.com/user/batvette/library/passportstereo
batvette
Has thanked: 7 times
Have thanks: 15 times
Postby fantasoap » Fri Dec 23, 2016 12:55 pm
Thanks for the input!
Where would you go for schematics and factory repair manuals?
fantasoap
Postby QuantumRift » Sat Dec 24, 2016 12:27 am
Just about any of us have schematics to scan and post for you. But yes, a corroded and loose connection can play havoc with your sanity.
Definitely check ALL the alternator wires and connections for tightness and corrosion.
Has the ignition switch ever been changed or checked. I ask because many many years ago I ran into a similar problem with a Ford and bad igniton switch. Bad conections, and a heavy key fob caused the engine and charging system to go a bit nuts on bumpy roads. Wasn't my car, but a friend's car. When he drove it, no problem. When his wife drove it, problems because she had a BIG heavily loaded key fob that caused ignitions switch problems....just a thought.
"If Opportunity knocks and he's not at home, Opportunity waits."
"Find out what it is in life that you don't do well, then don't do that thing."
1990 Isuzu LS SpaceCab 4x4 (Japanese-built, September 1989)
224,000 miles.
K&N Air Filter
2.6 L 4ZE1 engine, 5-spd manual
Monroe Sensa-track Load Adjusting Shocks (rear)
Monroe OE Spectrum Shocks (front)
MagnaFlow Muffler & Cat Converter
Akebono ProACT Ultra-Premium Ceramic Brake Pads (front)
Wagner Thermoquiet Ceramic Brake Pads (rear)
Owned since 15 miles. Bought new Honolulu, HI in Oct '89.
Original sticker price: $15,000.
QuantumRift
Has thanked: 23 times
Have thanks: 98 times
Postby gb89amigo » Sat Dec 24, 2016 6:38 pm
fantasoap wrote:Hello and thanks in advance... I'm inexperienced with electrical systems.
Patient facts:
As far as factory manuals go, you have to troll eBay and Amazon on a regular basis. Otherwise could try: http://www.reliable-store.com/products/ ... ice-manual or http://www.reliable-store.com/products/ ... hop-manual
Have not tried them myself, but looks good! Best of luck,
Cheers and Merry Christmas,
GB
'89 Amigo XS RWD, 4ZE1, MUA5, HC6 (Rear Wheel Drive, 2.6L Fuel Injected, 5 spd trans f/ 2.6L and up, 4.56:1 differential 2WD/4WD)
Future: Install the "Big Brake" upgrade, so I don't break things! . Acquired '95 V6 Passport/Rodeo front rotors (11.04") and assemblies. Need to pull G80/LSD rear from '92-'97 Trooper.
'90 Amigo 4WD, Parts car
More FUN!!! :)
gb89amigo
Has thanked: 46 times
Have thanks: 115 times
Postby fantasoap » Sun Jan 01, 2017 6:15 pm
Thanks everyone for your support!
fantasoap
Postby fantasoap » Thu Jan 05, 2017 2:22 pm
Hi
I took the alternator to O'Reilly's. They say it's good.
There's a blue relay under the hood, labeled "Charge". According to the wiring diagram (attached) it illuminates the charge warning light if the alternator is not charging the battery.
I believe I have narrowed the problem down to this relay, but, logically, I am not sure that it has any influence on the actual charging of the battery. The diagram is confusing on that point.
I do not understand why there are five terminals on the relay instead of four.
fantasoap
Postby fantasoap » Wed Jan 11, 2017 9:07 pm
The charge relay was faulty. Replacing it solved the problem.
I still don't know why it solved the problem, because I don't understand how the relay is actively involved in the charging process. I understand that it illuminates the battery light if there is no current coming from the alternator, but I don't understand the function of the circuit it switches to when the alternator is acting normally. Does anybody know how this works?
fantasoap
Return to Audio & Electronics
