Hi,
I need help knowing which speed dials are compatible, as I can only find cluster dash board; new they run in the $400 (almost just as much of KBB value!!! :shock: ) and eBay around 35 to 90 + 160 to adjust odometer to original :| , what I have found is that only 92, 93, & 94 are compatible for the cluster, is this true? or 95 to 97 are also compatible? this is because I can't find any 92 to 94 clusters in eBay, I have taken the speed dial out of the cluster, is this speed dial compatible with any other Isuzu vehicles? (Rodeo, Amigo...) I can see that the 98 on Troopers the odometer is digital so I would think they are not compatible with mine but some of the Rodeos and the Trooper 95 to 97 look very similar.
Many thanks in advance.
