Door locks/Alarm system/windows problems
Postby ZooMaster » Mon May 02, 2016 4:39 pm
So on my trooper (2000) I've been having problems with the door locks, windows, and alarm system. Basically none of my keys will unlock the other doors from the drivers door, only the drivers door will unlock, and if I try to open it the alarm goes off. Also at the same time the windows won't go down from any of the doors, I know thy work cause they have before and this generally only happens whenever the alarm gets set off. My car is equipped with the remote key system but the dongle is dead right now so I can't see if it would work with that.
Any ideas on what's up? I'm guessing it's something incredibly simple that I don't know
2000 Isuzu Trooper (145k/2016)
ZooMaster
Drives in Mud
Re: Door locks/Alarm system/windows problems
Postby vtxstar » Wed May 04, 2016 6:44 am
When you say '..none of my keys will unlock the other doors from the driver's door..' do you mean the physical key as inserted into the lock?
If the keys are cut the same, could the locks must be damaged? I am not clear on this point.
Do you have any resource material -- books, schematics, drawings? If not, we will have to attach/post them here to help.
-=Doug
'IT ≠ IQ ' Starwalt 1999
1999 Rodeo LS
UEB7VF AJ/JI
Trooper 6VE1 under the hood!(I've got pictures!)
vtxstar
Has thanked: 2 times
Have thanks: 6 times
Postby ZooMaster » Wed May 04, 2016 12:47 pm
By "won't unlock the other doors" I mean the central locking system (when you can unlock/lock the other doors from the drivers/pass with a key) won't unlock or lock the other doors (pass, rear doors) sorry if I wasn't as clear with it.
And no I don't have any resource material, any would be great, thanks.
ZooMaster
Drives in Mud
Postby vtxstar » Thu May 05, 2016 6:16 am
Thank you for the clarification.
It sounds like the driver's door key switch(es) or wiring/path or door control module (and any combination of them) may be at issue here.
Does the driver's inside door/window control panel work correctly? (representative part below)
-=Doug
1999 Rodeo LS
UEB7VF AJ/JI
vtxstar
Postby vtxstar » Thu May 05, 2016 7:33 am
Here is the Door Lock information from my 1999 Isuzu Rodeo/Amigo Manual (Power Locks with Keyless Entry)
Hope it helps!
-=Doug
1999 Rodeo LS
UEB7VF AJ/JI
vtxstar
Postby ZooMaster » Thu May 05, 2016 12:03 pm
Cool thanks for the diagrams, the window switches works at times, if the car alarm goes off does that disable the windows? Cause that's when I notice when the windows don't work.
ZooMaster
Drives in Mud
Postby vtxstar » Thu May 05, 2016 4:18 pm
Nothing in the schematic for the Anti-Theft system suggests the windows are disabled.
Below is the operational description of the circuit.
-=Doug
1999 Rodeo LS
UEB7VF AJ/JI
vtxstar
Postby alabamaoverland » Wed Apr 19, 2017 10:39 pm
So if I have a anti theft system, do I also have keyless entry? How do I know if I have it or not?
2000 Green Isuzu Trooper 4x4
alabamaoverland
Has thanked: 8 times
Postby Buster28 » Thu Apr 20, 2017 11:38 am
alabamaoverland wrote:So if I have a anti theft system, do I also have keyless entry? How do I know if I have it or not?
Factory installed or aftermarket anti theft system?
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
Buster28
4L30E Guru
Have thanks: 876 times
Postby alabamaoverland » Thu Apr 20, 2017 1:31 pm
It has the blinking anti theft light on the dash from the factory.
alabamaoverland
Postby Buster28 » Thu Apr 20, 2017 3:17 pm
The factory Anti-Theft and Keyless-Entry share a common electronic module.
Buster28
4L30E Guru
Return to Audio & Electronics
