99 Rodeo how to disable factory alarm
Re: 99 Rodeo how to disable factory alarm
Postby 6chevy7 » Mon May 04, 2015 3:59 am
can someone please pm me this info also if it will work on a 2002 rodeo thanks
6chevy7
Postby allpats » Mon Nov 23, 2015 1:47 pm
Hi
Is anyone still maintaining this thread. I need to disable my factory alarm too.
allpats
Postby Goauld » Wed Nov 25, 2015 5:28 am
To disarm factory alarm you must find white plug and yellow/blue wire in drivers kick panel and ground it.
2000 Isuzu Rodeo LS 3.2 V6 ; GOLF IV 1.9TDI
Goauld
Drives in Mud
Has thanked: 4 times
Have thanks: 6 times
Postby rodeorat » Sat Nov 28, 2015 7:43 am
I have 98. I'd the instructions on disabling the alarm as well. Could someone please pm me the instructions?
rodeorat
Postby rodeorat » Sun Nov 29, 2015 7:11 pm
Is it true that grounding the yellow/blue wire will cause a drain on the battery? Looks like there would be some simple way to unplug the hood switch and "rig" the wires at the hood switch to make it think the hood is always open. That would eliminate the possibility of hood switch being/going bad. How does the hood switch work? If the plunger on the switch is up-is it connecting the wires? Disconnecting them? Seems like it should be something pretty simple going on there.
rodeorat
Postby zillioxg » Fri Feb 05, 2016 5:46 pm
My 99 Rodeo alarm is now going off when ever it decides to. Can some one also please PM me the instructions as to how to safely disarm the alarm system, in a way that won't drain the battery. Thank you.
zillioxg
Postby radare » Sun Feb 07, 2016 4:08 am
zillioxg wrote:My 99 Rodeo alarm is now going off when ever it decides to. Can some one also please PM me the instructions as to how to safely disarm the alarm system, in a way that won't drain the battery. Thank you.
It's probably better to diagnose and repair the problem with your factory security system, rather than try to band-aid it by disabling it. When you lock the doors, does the system arm without issue or give you the multiple beeps?
radare
Have thanks: 39 times
Postby hogribbs » Tue Feb 09, 2016 3:31 am
Would like too also have a PM on this subject.. also don't like the doors locking for a warm up on cold AM's
hogribbs
Has thanked: 2 times
Postby rontontui » Fri Jul 29, 2016 6:30 pm
I have a 1999 and my car alarm will not turn off no matter what I have tried so far. All lights flash and horn goes off. I've pulled the horn fuse so my neighbors will stop complaining. Lets me drive it though. Please let me know how I can disable the alarm.
rontontui
Postby rontontui » Fri Jul 29, 2016 7:23 pm
Would also like a PM. Tried everything I can think of but my horn keeps going off and lights keep flashing no matter what I do.
rontontui
Postby radare » Sat Jul 30, 2016 10:23 am
rontontui wrote:Would also like a PM. Tried everything I can think of but my horn keeps going off and lights keep flashing no matter what I do.
What does your Rodeo do when you lock the doors with the remote keyfob? Does it beep at you and lock?
radare
Postby Rivera5 » Fri Aug 12, 2016 12:10 am
I have a 1998 Isuzu Rodeo that has a bad transmission so it has set for quite some time and now we are trying to fix it but have lost the remote to arm and disarm the alarm. Our Rodeo is unlocked and I have my keys but the battery was dead and now the alarm just goes off continually once the battery is connected to jumper cables and I have no way of turning it off. Does anyone know how to do this since I am not able to find the remote anywhere.
Rivera5
Postby Rodeo814 » Sun Apr 30, 2017 2:15 am
I also just had a viper keyless remote start installed and my rodeo is going crazy. Please someone help. I'm off tomorrow and would like to compete this task asap. Thank you!!
2000 Rodeo 4WD 3.2 V6 (133K)
4.10 Gears factory LSD
OME 912 springs, Rancho9000XL shocks, HD torsion bars, HD lower links, Calmini Upper Control arms
BGF KO2 285/75R16
Yakima Road Warrior Rack
Rodeo814
Previous
Return to Audio & Electronics
