Bulb part number? *Solved/Identified*
Postby IMYooper » Thu Apr 27, 2017 2:18 am
Pulled the dash cover on my '99 Amigo and I am having trouble identifying the bulb part number for the dash-board clock. Does anyone have information pertaining to my inquiry? The clock bulb was inoperative and I yanked it out but I can't find any number on the old bulb. I have a batch of miniature bulbs but this one is odd. It is a closed glass bulb with exposed wires that get wrapped under the bulb housing to make contact with the circuit board to get illumination. It is very tiny and my older eyes cannot see any number even with a magnifier.
As a side note, I found (after pulling the dash cover) why I can't get rid of the "Dead Mouse Smell" from my Isuzu. The entire center dash air vent was packed with insulation, seeds and mouse droppings (vehicle sat idle at a farm for quite a while). I thought I got it all when I cleared out the entire air box of insulation and the glove box was packed too. I have gone through a bottle of Febreeze, several air deodorizers and a bunch of dryer sheets. Now, hopefully, it won't smell like Mickey Mouse's litter box.
1999 Amigo S, 4X4 with hardtop. 3.2L 6VD1.
RIP: 1998 Rodeo 4X4, 3.2L 6VD1
IMYooper
Have thanks: 6 times
Re: Bulb part number?
Postby Dingbat » Thu Apr 27, 2017 10:34 am
I think there are two different sizes used one is 194 the other is 74, not sure which your's would use in that location.
1997 UCS7VF (Rodeo / Passport / Frontera)
Wry Wench build thread
3-inch Calmini Lift Kit, Indy4x 1.5-inch Leaf Lift
Dingbat
Have thanks: 61 times
Postby IMYooper » Thu Apr 27, 2017 9:44 pm
Thanks for the reply but those are going to be too large for the clock application. I did some research and I think I found the bulb that is required. For those that also have a burnt out clock light, look for bulb #7219 (miniature bulb, T-1, wire base). Click Here from "Bulbtown".
Here is a photo of what I am talking about.
IMYooper
Postby IMYooper » Wed May 03, 2017 10:58 am
Alrighty then...got my package of 10 bulbs (#7219) in the mail yesterday. I replaced the backlight for the dash clock, 4WD switch and Rear defrost switch (all were burnt out). I removed the old bulbs and inserted the new along with the Blue rubber diffuser. All the dash switch back lights are now operative. Very pleased now I can see switches in the dark. :D
IMYooper
Re: Bulb part number? *Solved/Identified*
Postby rbral » Mon May 15, 2017 8:17 pm
Nice! Thanks for the part number!
Bob
2002 Trooper
98 Blazer
rbral
Return to Audio & Electronics
