Keyless entry programming 2002 trooper
Postby Reynoldsrr63 » Sun Apr 23, 2017 10:25 pm
I bought a 2002 Trooper Limited a couple years back, was never given a remote for keyless entry. I just finally got around to buying a pair of remotes, but now I can't seem to get it to reprogram to except them. Door open, key in, switch to ACC & lock 3 times in 3 seconds​, close & open door twice, switch to ACC & lock 3 times in 3 seconds, close & open once, locks should cycle, but I can't seem to make that happen. Could I have some other issue besides not timing it right? Vehicle has power door locks, power windows, & there's an anti-theft light that binks. Help please!
Reynoldsrr63
Re: Keyless entry programming 2002 trooper
Postby Buster28 » Mon Apr 24, 2017 8:37 pm
What is the FCC ID number stamped on the back of the remote?
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
Buster28
4L30E Guru
Have thanks: 874 times
Postby Reynoldsrr63 » Mon Apr 24, 2017 9:04 pm
The remotes I bought are blank on the back, that isn't the issue (yet) I can't even get the vehicle to enter program mode to even see if it will reprogram to the new remotes.
Reynoldsrr63
Postby Reynoldsrr63 » Tue Apr 25, 2017 2:07 pm
Can someone tell me where the keyless entry module is and how to tell if it's good or not?
Reynoldsrr63
Postby Buster28 » Wed Apr 26, 2017 9:38 am
If the power door locks work the module is probably working.
You will have to remove the lower dash pad to gain access.
Buster28
4L30E Guru
Postby Reynoldsrr63 » Wed Apr 26, 2017 10:41 am
Power door locks work using interior switchs and turning key in door locks twice opens all locks (driver's door and passenger's door only not rear door, rear door lock only unlocks rear door)
Reynoldsrr63
Return to Audio & Electronics
Users browsing this forum: Google Adsense [Bot] and 2 guests
cron
