Tachometer
Tachometer
Postby thumper » Sat Apr 15, 2017 1:54 pm
I am need to know what wire on the top of distributor of 95 Isuzu Pickup 2.3 L to splice into and install a tachometer. There are two sets of wires both leading into the distributor side of the coil pack. Does anyone know which set I will splice into, the first set facing the front of the truck or second set facing the firewall? Any advice would be highly appreciated, thanks in advance.
:happy10:
Thumper, Boise, Id.:roll: :roll:
thumper
Re: Tachometer
Postby thumper » Sun Apr 16, 2017 5:34 pm
thumper wrote:
I am in of need to know what wire on the top of distributor of 95 Isuzu Pickup 2.3 L to splice into and install a tachometer. There are two sets of wires both leading into the distributor side of the coil pack. Does anyone know which set I will splice into, the first set facing the front of the truck or second set facing the firewall? Any advice would be highly appreciated, thanks in advance.
So I tried the black wire with yellow stripe that comes from the coil and leads to the distributor but that didn't work! Is it possible to fry my coil by splicing into the other three (separately) of course? :roll:
:happy10:
thumper
Re: Tachometer
Postby JoeIsuzu » Mon Apr 17, 2017 9:52 am
thumper wrote:
I guess no one on this site knows, thanks allot, I'll find another site.
I don't think you'll even come close to finding a better, more helpful site for the truck you have.
Isn't it pre-wired for a tach? I'm surprised that there's a need to splice anything directly to the distributor.
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 73 times
Have thanks: 76 times
Re: Tachometer
Postby thumper » Mon Apr 17, 2017 10:30 am
I imagine for the factory but I am unsure of where the wires are. I picked this tach up for a decent price, mounted nicely on my dash and looks good. As I was reading some other posts yesterday one person said they spliced into the black wire with yellow stripe, I tried that one to no avail. Can I fry my coil trying the other three by chance?
:happy10:
thumper
Re: Tachometer
Postby plaDURTy » Mon Apr 17, 2017 11:18 am
black/red unplug it its the one without 12volts with the key on
plaDURTy
Re: Tachometer
Postby thumper » Mon Apr 17, 2017 7:05 pm
But one is black and red and the other blue on mine.
:happy10:
thumper
Re: Tachometer
Postby thumper » Mon Apr 17, 2017 7:08 pm
Thanks for the reply
:happy10:
thumper
Re: Tachometer
Postby plaDURTy » Mon Apr 17, 2017 7:46 pm
Black/red & black/yellow body side. Black/red black blue distributor side of the harness connector.
plaDURTy
Re: Tachometer
Postby geoffinbc » Thu Apr 27, 2017 1:38 am
Find out what side of you coil is the 12V power. Put the key in run to check. The other side is the ground trigger. This is where your tach connects.
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Re: Tachometer
Postby Darby » Thu Apr 27, 2017 12:45 pm
This splice is to connect my hand held tach. I'm partially color blind, so I'm not sure if that wire is blue or purple.
Original owner of a 1993 Isuzu pick up, 2.3 engine, 5 speed with power steering and air conditioning. All original except the radio (still have factory radio).
It's cheaper to fix what you have than to buy someone else's problems.
Darby
Super Trooper
Have thanks: 19 times
Re: Tachometer
Postby thumper » Fri Apr 28, 2017 8:07 pm
Thank you I appreciate it. I tested again and found the negative but I have to re-do the positive into the ignition.
:happy10:
thumper
Return to Audio & Electronics
Users browsing this forum: Baidu [Spider] and 1 guest
