Where does this go?
Where does this go?
Postby PassportEX » Tue Feb 21, 2017 8:37 pm
Putting my 2.6l head back together and im left with one pigtail. Its at the end of the wiring loom under the manifold near the distributor. I know its not injectors, coil pack and ignitor. Any guidence will be greatful.
1990 Pickup 2.6l
97 Honda Passport 4x4 V6
PassportEX
Re: Where does this go?
Postby Darby » Tue Feb 21, 2017 11:21 pm
Three wires. Throttle position sensor?
Original owner of a 1993 Isuzu pick up, 2.3 engine, 5 speed with power steering and air conditioning. All original except the radio (still have factory radio).
It's cheaper to fix what you have than to buy someone else's problems.
Darby
Have thanks: 19 times
Postby PassportEX » Wed Feb 22, 2017 12:54 am
Dont think its the position sensor. Got that hooked up as well Cant really find anything on the head that is missing unless that wire connect to something in the engine bay that I dont see.
Here is another front picture of the connector.
PassportEX
Postby MarkB.NV » Wed Feb 22, 2017 1:39 am
I'm thinking that is the 2-wire connector for the EGR temp sensor. California spec vehicles had an extra circuit to feed that temp info to the ECM and if things were not copacetic then you'd get a Check Engine Light (CEL). If the emissions tab under the hood says Federal then you can probably ignore it as a CA only thing. And as far as I know is specific to the 2.6 liter 4ZE1 motors.
MarkB.NV,
Tan 1986 Trooper, 2.6 / 5 speed, 173K mi.
http://forum.planetisuzoo.com/viewtopic.php?f=15&t=101538
White 1984 Trooper, 1.9 / 4 speed, 89K mi.
http://forum.planetisuzoo.com/viewtopic.php?f=15&t=85764
Sold ... Silver 1990 Trooper, 4 cyl, 5 speed
Sold ... Blue 1989 Trooper, 4 cyl, 5 speed
MarkB.NV
Has thanked: 66 times
Have thanks: 137 times
Postby PassportEX » Thu Feb 23, 2017 2:11 pm
Is there any other way to distinguish if this truck is California spec? Not sure what happened, but my hood doesn't have anything under it not even a vacuum diagram. Where would I find the EGR temp sensor if I do have a California spec truck?
PassportEX
Postby superman27344 » Thu Feb 23, 2017 3:00 pm
Your computer (located under the center console) will say on it as well.
Lou
2000 Trooper aka "Brawn", 3.5 liter V6, 5spd
1989 Trooper aka "The Armadillo", 2.6 liter, 5spd SOLD
Carolina Isuzu Owners Facebook Group
Brawn Build Thread
The Armadillo Build Thread
"It has been my experience that folks who have no vices have very few virtues."
-Abraham Lincoln
Has thanked: 420 times
Have thanks: 76 times
Postby PassportEX » Fri Mar 10, 2017 5:31 pm
Thanks all.
PassportEX
Return to Audio & Electronics
