2001 Trooper radio light bulbs
Postby 1Trooper » Tue Feb 21, 2017 6:55 pm
Has anyone replaced the light bulbs in the original radio that came with the Trooper? Are they soldered type bulbs or what type? Mine is a 2001 year,
Thanks
1Trooper
Has thanked: 2 times
Re: 2001 Trooper radio light bulbs
Postby ravi261 » Tue Feb 28, 2017 11:22 pm
They're smds (surface mount diodes). You can do it, but you have to be pretty precise with a soldering iron and try not to burn the board. Once you remove the volume knob, the front face is held on by push tabs all around face. The face electrical connector is a slip type connections so as long as you pull it off straight you shouldn't have a problem.
I'd suggest opening the face and look at it and then decide if you want to attempt it.
1999 3.2 V6 4wd Rodeo LS 178k 4L30-E
For the 1st time since 2006, everything works! (including ABS :) )
ravi261
Have thanks: 67 times
Postby brcobb » Wed Mar 01, 2017 2:25 pm
In my '01 Rodeo, all of the radio lights were no longer working. I decided it was easier to just replace the radio. I picked up a Radio/CD combo from my local pick-a-part for $10.
01 Rodeo LS 4x4 - V6 3.2L
4 Speed Automatic
370,000 miles
01 Rodeo LSE 4x4 - V6 3.2L
4 Speed Automatic
155,000 miles
brcobb
Have thanks: 5 times
Postby 1Trooper » Mon Apr 03, 2017 6:30 am
Thanks for the responses. I'll probably go the used radio route as well.
1Trooper
Return to Audio & Electronics
Users browsing this forum: Google [Bot] and 1 guest
