3.2 MAF reading 2.9g/s Good or bad?
Postby mchl1cox » Wed Jan 11, 2017 7:47 pm
I have a MAF sensor reading of 2.9 g/s @756rpm STFT1 51.6% intake 54.0kPa vacuum reading is 13.985 in/Hg what does this mean?
mchl1cox
Has thanked: 8 times
Re: 3.2 MAF reading 2.9g/s Good or bad?
Postby Buster28 » Thu Jan 12, 2017 8:13 am
The MAF reading is too low, it should be about 7.6 Grams/Second
The STFT is too high, it should be closer to zero
The MAP reading is too high, it should be about 30Kpa
It appears you have a vacuum leak, allowing air to get into the engine without being measured by the MAF
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
mchl1cox
Buster28
4L30E Guru
Have thanks: 824 times
Postby mchl1cox » Thu Jan 12, 2017 6:30 pm
Thanks again for your input Buster28, I have replaced most vacuum lines that I can locate, it does seem to be some behind the motor, kinda hard too get too though, would I have too remove the plenum too get too them? This is my only vehicle and trying too do repairs as quickly as I can. Thanks again!
mchl1cox
Postby gwana66 » Fri Jan 13, 2017 3:11 pm
Plenum gaskets are a likely culprit anyway.
Even the hubs are manual now.
For this post the author gwana66 was thanked by:
mchl1cox
gwana66
Have thanks: 180 times
Return to Drivetrain Problems
Users browsing this forum: Bing [Bot] and 4 guests
