2001 Rodeo 20mph max
Re: 2001 Rodeo 20mph max
Postby RDUBB901 » Tue Oct 20, 2015 8:50 am
Hello Buster. I checked the pins and the whole area for corrosion. I didn't find anything. Everything looks good. Also, is that an alright ohms reading that I gave for the speed sensor? Could it be working but giving bad info? I don't know what the reading should be so I was just asking. But everthing on the pins did look clean. Again, any help or answers that you can give is greatly appreciated. Thanks.
RDUBB901
Postby Buster28 » Tue Oct 20, 2015 10:01 am
The resistance of the speed sensor is typical for that type of device. Further, if the PCM did not receive a correct signal from the speed sensor DTC P0722 should be set along with the CEL being illuminated. Additionally, the speed sensor is not involved in selecting Winter Mode which is not working as expected.
Since the wiring from the PCM to the solenoids is OK and the solenoids are new, it is possible the PCM is defective. To see if the PCM is properly controlling the shift solenoids you could hook up a Red and a Green 12 Vdc LED in parallel with each solenoid. When the PCM energizes the solenoid the LED will also illuminate. If you use Red for shift A and Green for shift B you can tell what the PCM is commanding. The alternative is too obtain a scan tool that can monitor the shift solenoids.
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
alsilva01
Buster28
4L30E Guru
Have thanks: 884 times
Postby RDUBB901 » Wed Oct 21, 2015 2:23 pm
Thanks Buster. 12 vdc LED. Where could I get them and also how should I hook them up? I'm not familiar with it. Sorry for so many questions. But thank you for answering them.
RDUBB901
Postby Buster28 » Wed Oct 21, 2015 4:06 pm
You can get the LED's at Amazon. The LED has a positive and negative lead. The positive of each LED is connected to E-22 Pin 43. The Green negative to E-21 Pin 5 (Shift A) and the Red negative to E-22 Pin 31 (Shift B). Basically, your substituting a LED in place of the ohm meter. Ideally you would want to splice wires to the vehicle harness wires and run them to the LED's located where you can see them.
The PCM energizes the solenoid by grounding the control which is why the positives are connected to E-22 Pin 43 which is +12 Vdc supply.
RED
http://www.amazon.com/Qty-Lights--wired ... led+lights
Green
http://www.amazon.com/Lights-wired-volt ... 160%2C160_
Buster28
4L30E Guru
Postby alsilva01 » Tue Feb 09, 2016 2:41 pm
hello rdubb901 I got the same exact problem I was wondering if you was able to fix you truck and what you did?
alsilva01
Postby rideforlifevegas » Tue Feb 09, 2016 8:41 pm
Same exact problem here to. What did uou do to gix it ?
Mine 2002 rodeo 3.2 4x4
I replaced. Solenoid A ..Solenoid B ...Control Solenoid. ..filter..gasket.....mode select swith .....mine will mot go forward with winter mode on....winter mode light works...power mode drives but same as if in drive position. ..I get only about 20 mph no shifting still. No trans light. No reduded power light.
rideforlifevegas
Postby alsilva01 » Thu Feb 11, 2016 7:55 am
hey rideforlifevegas I talk to buster he is a really good help and looks like is the transmission not electric like we was thinking he say is probably one of the couch to be exact is maybe the second cluch and the reason for that at least on my case was cause I have to drive it with very low ATF on it! if you can work on transmission there is an other conversation he got about this and he share a video where they show how to do it you self. am not that good about that so I will take it to a shop and I will post what happens when I get it back good look!
alsilva01
Postby Deezil » Wed Jan 11, 2017 8:17 pm
Well, figure it out? Mine does this too..
Deezil
Postby charlesdarwin » Mon Jan 23, 2017 7:01 pm
I've got the same problem. I've been slowly working on my 2000 Rodeo for a few months. The CEL has been on with numerous codes including EGR, O2 sensor and shift solenoid. After removing and cleaning the EGR, MAF and throttle body I took the truck for a drive and as it shifted 3-4 it fell out of gear and would not accelerate beyond 20 mph. I've since dropped the transmission pan, pulled the valve body and removed the A and B solenoids. Both register appropriate ohms (~20 when cold), but when I applied a current to each from my battery the B solenoid would close but the A solenoid would not. I'm hopeful (not too much) that a new A solenoid will resolve the issue - but am prepared for defeat.
charlesdarwin
Postby Deezil » Mon Jan 23, 2017 7:12 pm
charlesdarwin wrote:I've got the same problem. I've been slowly working on my 2000 Rodeo for a few months. The CEL has been on with numerous codes including EGR, O2 sensor and shift solenoid. After removing and cleaning the EGR, MAF and throttle body I took the truck for a drive and as it shifted 3-4 it fell out of gear and would not accelerate beyond 20 mph. I've since dropped the transmission pan, pulled the valve body and removed the A and B solenoids. Both register appropriate ohms (~20 when cold), but when I applied a current to each from my battery the B solenoid would close but the A solenoid would not. I'm hopeful (not too much) that a new A solenoid will resolve the issue - but am prepared for defeat.
Hows your trans fluid? smell burnt? Mine was diagnosed by a shop, they said its shot... hard to find a low mile used trans, rebuilt ones are expensive, so looks like Im stuck rebuilding it myself :/
Deezil
Postby charlesdarwin » Mon Jan 23, 2017 7:25 pm
I'm probably there with you, but don't have the skills to rebuild myself. I inherited this Rodeo from my dad about 3 years ago - it was his hunting truck, so likely didn't have the best service for the 6 or so years he had it. I changed the oil and had a head gasket replaced, but not much beyond that before the CEL came on last summer. In October the transmission slipped out of gear and would not engage at all. That's when I decided to drain the fluid. It was burnt, for sure, and the filter was filthy. I replaced the filter and fluid - and double checked levels. This worked. The transmission seemed fine until two weekends ago when it dropped out of gear and would not go above 20mph. I drained again - the ATF was full of sludge, not a good sign, I know. I should be thankful for the additonal 3.5 months that I got out of it.
The solenoid is my last shot - probably futile, but worth a shot.
00 Rodeo LS 4X4 3.2L V6
March '17 rebuilt transmission (@144,470 mi)
charlesdarwin
Postby charlesdarwin » Mon Jan 23, 2017 7:27 pm
Deezil, good luck with the rebuild, BTW, and be sure to post the progress as I enjoy reading about it.
charlesdarwin
Postby Deezil » Mon Jan 23, 2017 7:33 pm
I will, Im pretty mechanical, but never opened up an auto trans yet, I guess I have nothing to lose at this point. :)
Deezil
Postby charlesdarwin » Mon Jan 23, 2017 7:52 pm
Right about that.
charlesdarwin
Postby charlesdarwin » Sun Jan 29, 2017 4:36 pm
Well the new A and B solenoids came Friday and I installed them along with new filter and ATF on Saturday. R, 1 and 2 still works, but 3 and Winter drive are no go. Afraid the tranny is shot.
charlesdarwin
Postby TurboD16 » Mon Jan 30, 2017 2:48 pm
My 02 had this issue. It ended up being all of the 2nd gear clutch pack was burnt up. After a rebuild it was good for 25k, until now it sometimes struggles to get into 1st or reverse. If i click winter mode, it goes right in. Ideas?
TurboD16
Previous
Return to Drivetrain Problems
