axiom transfer case dash switch
Postby Tg16 » Thu May 18, 2017 2:34 am
is it possible that the Transfer case is stuck in Neutral?
The axiom does not have a shift lever for the transfer case it's just a dash button.
has anyone ever had a axiom or rodeo with the dash switch transfer case get stuck in neutral?
1998 SLX
2000 Trooper
2002 Rodeo
Tg16
Re: axiom transfer case dash switch
Postby CyrodiilSavior » Thu May 18, 2017 10:25 pm
It seems unlikely the dash switch broke although I suppose its definitely possible. It seems more likely to me that the servo motor which moves the shift ford inside the transfer case went bad. Unfortunately I've never worked on this style and don't have any wiring diagrams. If you had them you could probably find a way to jump past the switch bypassing it completely.
99 Trooper. Black 170k miles - April 2015 AT Rebuild (Soon to be have 4JG2T swap :wink: )
99 Trooper. Green 240k miles. - April 2013 AT Rebuild/December 2013 Engine Rebuild/April 2016 SUPERCHARGED!
CyrodiilSavior
Have thanks: 9 times
Postby Tg16 » Fri May 19, 2017 3:36 am
is it possible the trasnfercase could be in neutral or stuck in neutral
1998 SLX
2000 Trooper
2002 Rodeo
Tg16
Postby CyrodiilSavior » Fri May 19, 2017 6:05 am
I've never heard of that before. Seems very unlikely. It's the same transfer case except yours uses a motor rather than a manual shifter. Aside from that it's pretty much the same.
CyrodiilSavior
Return to Drivetrain Problems
Users browsing this forum: No registered users and 4 guests
