So i just want to confirm my thoughts..
Postby thepotz » Tue May 16, 2017 7:20 pm
So I started burning coolant. Every once in a while a big cloud of coolant smelling white smoke. So I figured bad head gasket and replaced it. But still has coolant leak and white smoke. Oil is fine. Not milky whatsoever, so I am concluding cracked head. Does everyone agree? Or am I missing something else?
89 Trooper 2.6 Everything stock, torsion turn, add a leaf, round headlight grill, custom turn signals, early rims
thepotz
Drives in Mud
Re: So i just want to confirm my thoughts..
Postby MrDunge » Tue May 16, 2017 7:30 pm
Cracked or warped. Have you done a compression test and if so what were the #s
Evil Thrives When Good People Do Nothing
89 Trooper 2.6
87 Trooper 2.3 (salvaged)
02 Trooper 3.5 (salvaged)
MrDunge
Super Trooper
Have thanks: 18 times
Postby thepotz » Tue May 16, 2017 7:50 pm
No compression test yet but I am just trying to nail down the problem component
thepotz
Drives in Mud
Postby MrDunge » Tue May 16, 2017 8:02 pm
OK. The only way for coolant to enter the combustion chamber to be burned and create white smoke out the exhaust is one of 4 ways. Head gasket failure, warped head, cracked head, or incorrect torque pattern, torque ft lbs on the reinstall.
89 Trooper 2.6
MrDunge
Super Trooper
Postby MrDunge » Tue May 16, 2017 8:06 pm
The best way to see what cylinder(s) are the culprit is via a compression test. Anything above 120lbs is good and no more than about 15% difference in pressures between cylinders.
89 Trooper 2.6
MrDunge
Super Trooper
Postby thepotz » Wed May 17, 2017 7:30 pm
Ok. Thx for the replies. I know the head was tightened correctly and holes were chased with a tap. Sounds like a confirmation on bad head. Either warped or cracked. I figure if the block was cracked at the cylinder wall I would surely get coolant in the oil. Thx for confirming my thoughts
thepotz
Drives in Mud
Postby thepotz » Sat May 20, 2017 2:09 pm
Update... Odd thing... When I use my heater, it smokes way worse than when I don't? Thoughts?
thepotz
Drives in Mud
Return to Drivetrain Problems
Users browsing this forum: Yahoo [Bot] and 4 guests
