Code P0440: Looking for Purge Solenoid
Postby ambient spark » Sat May 13, 2017 4:26 pm
Hi all.
Just got check engine code p0440. Google search suggests:
Possible Causes of P0440 Code
A Leak in the System
Faulty Purge Solenoid (This is the valve that lets the fumes into the engine)
Faulty or loose fuel cap
Faulty or Loose NVLD (This is the sensor that senses whether the system is working or not)
Less Common Causes
The Computer
Leaky Fuel Tank
Bad Charcoal Canister
So, A new purge solenoid is just 20 bucks or so so I'll replace it and see what happens. Anyone know where this part is located? looked but found nothing.
Also, what is an NVLD???
Vehicle:
Isuzu Rodeo 2001 3.2L V6
Thanks!
ambient spark
Re: Code P0440: Looking for Purge Solenoid
Postby Buster28 » Sat May 13, 2017 4:41 pm
Check this thread for a discussion of this problem
http://www.planetisuzoo.com/viewtopic.p ... =4&t=75664
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
Buster28
4L30E Guru
Have thanks: 876 times
Return to Drivetrain Problems
