Leaking Transmission Electrical Connectors
Postby hometheaterman » Tue May 09, 2017 9:49 pm
As I continue to try to track down leaks on my transmission in my 96 Trooper, I'm thinking maybe the electrical connectors are leaking as I see old fluid around them. I know Jerry told me in the last that the o rings sometimes fail allowing these connectors to leak. Has anyone experienced this? Do you know what size o rings I need? Also, how do you remove the connectors to change these o rings?
hometheaterman
Re: Leaking Transmission Electrical Connectors
Postby Buster28 » Wed May 10, 2017 10:04 am
The O ring is part of the connector
https://cobratransmission.com/4l30e-con ... ing-6050-1
https://cobratransmission.com/connector-4l30e-6032-1
To replace the O ring or the connector you have to remove the ATF pans and disconnect the internal connector. The external connector is a twist to lock in the case configuration. The probability you can remove a 21 year old connector from the case without breaking it is 50/50.
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
Buster28
4L30E Guru
Have thanks: 876 times
Postby hometheaterman » Thu May 11, 2017 12:00 am
Thank you for the advice. It sounds like replacing the connectors is the way to go. Unfortunately it may have to wait a little while. I was hoping I'd be able to do it without dropping the pan, but that's not the case.
hometheaterman
Return to Drivetrain Problems
