Transmission problems - 1991 trooper XS 2.8
Postby jgreenhouse » Tue May 09, 2017 9:01 pm
Hey All,
Recently purchased a gen1 1991 trooper XS. Love everything about it. Had one growing up and now i cant wait to start the mods.
I plan on throwing on a 1.5-2" lift with 32" all terrain tires. Also, would like to install a low profile roof rack and lights.
Before i can do that i need to resolve some issues with the cars shifting. Its an automatic and when it gets to operating temperature it seems to fall out of gear at stop lights. It feels like when im stopped at a light and my foot is on the break it goes into neutral. If im on a incline and let off the break i will roll without stopping. As i try to accelerate when the light turns green the car doesnt go anywhere and then eventually, with enough gas, jolts forward into gear as if i let the clutch out to fast (if it were a manual).
Any ideas what could be going on ?
Thanks,
Jake
jgreenhouse
Re: 1991 trooper XS
Postby itsmehb » Wed May 10, 2017 5:46 am
Which engine do you have. I believe the transmissions are different between the 2.6 and 2.8 engines.
Has thanked: 115 times
Have thanks: 202 times
Re: 1991 trooper XS
Postby jgreenhouse » Wed May 10, 2017 6:57 am
It's the 2.8
jgreenhouse
Re: 1991 trooper XS
Postby itsmehb » Wed May 10, 2017 12:40 pm
Pretty sure that's the 4L30E Transmission. Buster28 is our forum expert on this tranny, but probably won't see this post till you change the headline or repost as tranny trouble.
For this post the author itsmehb was thanked by:
jgreenhouse
Re: Transmission problems - 1991 trooper XS 2.8
Postby jgreenhouse » Thu May 11, 2017 9:02 am
thanks for the note, itsmehb.
I revised the headline.
jgreenhouse
Postby Buster28 » Thu May 11, 2017 11:24 am
Have you checked the AFT level?
02 Rodeo Sport 4X4 3.2L V6
Have thanks: 876 times
Postby jgreenhouse » Thu May 11, 2017 11:33 am
it was low originally but even after adding fluid the problem still persists
jgreenhouse
Postby Buster28 » Thu May 11, 2017 4:16 pm
When your at the stoplight can you accelerate normally if you shift into L (Manual 1st)?
Is there any delay or slipping in Reverse?
Postby jgreenhouse » Fri May 12, 2017 8:45 am
Unfortunately no. In L the problem still persists.
In Reverse there is absolutely no issue at all.
jgreenhouse
Postby Buster28 » Fri May 12, 2017 12:41 pm
jgreenhouse wrote:Unfortunately no. In L the problem still persists.
Slipping in L (Manual 1st) or Drive 1st but not in Reverse indicates the reaction drum brake band is slipping. It is probably worn out but you may be able to squeeze some more life out if it with an adjustment.
https://www.youtube.com/watch?v=bHWDxAwhzYc
jgreenhouse
Return to Drivetrain Problems
Users browsing this forum: Majestic-12 [Bot] and 5 guests
