test ecm
test ecm
Postby simm55845 » Wed May 03, 2017 12:13 pm
hello isuzoo nation,
how do you test a ecm on a 2001 isuzu rodeo ls 3.2 engine 4wd std. trans.?
thanks,
simm55845
simm55845
Has thanked: 69 times
Re: test ecm
Postby gwana66 » Wed May 03, 2017 1:42 pm
ECMs have hundreds of circuits. Individual functions can be tested using an OBDII interface like a GM TechII with bi-directional control or by comparing measured data to the values displayed by the scanner and referencing a wiring diagram. While it's in the vehicle, you can connect with a scanner and at least test for communications and stored codes.
As far as a bench test, I'm sure the manufacturer has a test rig of some sort, but the DIY'er has no hope of testing one that way. All we can do is throw it in the vehicle and see if it works.
Are you having a particular problem? ECMs hardly ever fail. They are well protected.
Even the hubs are manual now.
For this post the author gwana66 was thanked by:
simm55845
gwana66
Has thanked: 12 times
Have thanks: 198 times
Re: test ecm
Postby simm55845 » Fri May 05, 2017 12:08 pm
hello gwana66,
I hooked scan tool to truck,it read not responding to vehicle. I have used this scan tool for a lot of years, this is the
first time this happened.
thanks
simm55845
simm55845
Re: test ecm
Postby Buster28 » Sat May 06, 2017 11:42 am
simm55845 wrote:hello gwana66,
thanks
simm55845
If there is no +12Vdc reference power being supplied to the PCM/ECM/ECU or if the fuse supplying +12Vdc reference power to pin 16 of the DLC is blown the scan tool cannot communicate with the PCM/ECM/ECU.
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
simm55845
Buster28
4L30E Guru
Have thanks: 876 times
Return to Drivetrain Problems
