Correct grease for shifter, and cover removal?
Postby Doc » Mon May 01, 2017 2:25 am
SO I felt the need to clean this before I put it in. Had lots of grime on it. SO what is the correct grease to use i here without damaging anything. Ado is there a way to get that ripped boot off, or does the entire things need to be replaced?
...4:19...you got a minute?
Doc
Re: Correct grease for shifter, and cover removal?
Postby DSUZU » Mon May 01, 2017 5:29 pm
my understanding is you cut the old boot off and replace it with a new one from Jerry. I have not had success removing an intact used one. I would imagine a light dab of chassis or wheel bearing grease would be sufficient. Once it is running, the motor oil should work it's way up there. Dennis
Doc
Has thanked: 220 times
Have thanks: 624 times
Postby Doc » Mon May 01, 2017 5:50 pm
Thanks Dennis.
Yeah I am just gonna use all purpose grease in there. As for the dust boot...it's just gonna have to be torn for now. Thanks for the info good Sir.
Doc
Postby sanramonrover » Mon May 01, 2017 9:10 pm
If I recall correctly, once the lever knob is unscrewed and removed, the new boot will stretch enough to slide down over that thick part of the lever. I have in the past removed that thick portion off the lower part - but it was an H of a job and not worth the effort.
Keeping a 1991 KB Diesel, 4X4, 4 door Pickup on the road
sanramonrover
Drives in Mud
Have thanks: 5 times
Postby Doc » Mon May 01, 2017 9:44 pm
..kinda what I was thinking. Since much of this job was opening cans of worms..I think I am content with it having a small little rip. :lol:
Doc
Postby steve mortillaro » Thu May 11, 2017 9:15 am
I just did this on my Trooper and it was easy and the boot wasn't too expensive from Jerry. He included instructions: cut old boot off, place new boot in near boiling water for 5 minutes, lube gear shifter with dish soap and slide it on down. You will tear it if you try it dry. Worked a charm. The old boot on mine had been worn completely away at center and was pretty much done. Luckily the transfer boot wasn't so bad.
1986 Trooper II- My old beater- gone, but missed
1990 Trooper v6- Best vehicle I ever owned
1987 Toyota 4x4 pickup- Farm truck
2000 Ford E-250 xl- work van
steve mortillaro
Drives in Mud
Return to Drivetrain Problems
Users browsing this forum: monksphere and 8 guests
