2001 Isuzu Rodeo Sport wont start lights on dash
Re: 2001 Isuzu Rodeo Sport wont start lights on dash
Postby Buster28 » Fri Apr 28, 2017 5:50 am
The Red/Green wire connected to Pin 1 of the ECM/PCM relay goes to Pin 10 of body connector H-7 located in the engine compartment on LH inner fender. A loose or dirty connector may be the cause of the problem.
02 Rodeo Sport 4X4 3.2L V6
01 Rodeo Sport 4X4 3.2L V6
Buster28
4L30E Guru
Have thanks: 874 times
Postby vitamin_g » Fri Apr 28, 2017 5:47 pm
when i get home tonight & test to see if there is 12v on pin 10:
if no 12v or lower voltage, replace wire from relay to pin 10 location?
if 12v, where do I check next?
I just want to get to the next point. It seems as if you are done for the day when I am just starting my work. You help is immensely appreciated.
vitamin_g
Postby vitamin_g » Sun Apr 30, 2017 11:32 pm
Buster, thanks for all of your help. There was a loose connection in the H-7 wire bundle. I repaired the connection & the car starts up now & with all the correct voltages. Once again, thanks for all of your help.
vitamin_g
Postby Buster28 » Mon May 01, 2017 9:34 am
This is a good example showing why troubleshooting using a test lamp rather than a volt meter is a bad idea.
Buster28
4L30E Guru
Postby vitamin_g » Thu May 18, 2017 4:06 pm
correct on the test lamp for testing. thanks for your help on this issue.
vitamin_g
Previous
Return to Drivetrain Problems
Users browsing this forum: Yahoo [Bot] and 1 guest
cron
