Stick and slip
Re: Stick and slip
Postby ozfest » Tue Apr 18, 2017 10:16 am
The winter mode button will not stay depressed or light up. The power button does.
ozfest
Has thanked: 53 times
Have thanks: 5 times
Re: Stick and slip
Postby Holoholo » Tue Apr 18, 2017 1:26 pm
The buttons don't stay depressed, at least mine don't. Push winter from a stop, dash lights up and trans starts off in 3rd. It will then turn off. You need to push button at every stop to use it. Performance mode stays on till you press button again or shut off motor.
1997 Trooper 3.2 SOHC: Moog 6187 Impala spring lift, cranked torsion bars, Cooper A/T3 265/75R16, Ford F150 tie rod ends, braided brake lines, Energy Suspension swaybar bushings, Warn manual locking hubs, Dynomax Super Turbo muffler.
1997 Trooper 3.2 SOHC, stock.
Holoholo
Re: Stick and slip
Postby ozfest » Tue Apr 18, 2017 5:30 pm
Ok I'll be back at the vehicle tomorrow. Thanks !
ozfest
Re: Stick and slip
Postby ozfest » Mon May 08, 2017 5:28 pm
So after all was said and done I had it towed out to the trans shop. The one that the gentleman offered to look at it no charge . When I got there we spoke for a bit and he said he's very familiar with the trans as he also has a trooper. Left it there and a few days later I got a call . He said it needed a rebuild so it's $1,500. With a 1 year warranty .
I felt comfortable with the guy so gave the go ahead.
Thanks for all the input and help guys
ozfest
Previous
Return to Drivetrain Problems
Users browsing this forum: No registered users and 6 guests
