1995 Trooper Engine Replacement
Postby P-tricky » Sun Mar 12, 2017 8:15 pm
After being car-free for some time, my partner and I brought home this lovely base-model '95 Trooper.
It's in good shape, except for one thing: the head gasket blew and the PO took apart the top end of the engine before losing interest in the project. The radiator, water pump and timing belt were new when the gasket went out. The parts are all in the back, but I am leaning toward getting a donor vehicle (probably with a bad 4L30-E) with a running engine and swapping that in. I'm not sure how badly the heads and/or block may have warped when the gasket blew. It did come with new gaskets, a NIB clutch kit, and the factory service manual.
Do you all think that's the best route? Should I look at junkyards instead and pull just an engine? Try to rebuild the current one?
P-tricky
Re: 1995 Trooper Engine Replacement
Postby SuperTroop95 » Sun Mar 12, 2017 11:38 pm
Good luck. Those engines are not very easy nor fun to pull! When I swapped out my engine, I got one from the junkyard, I got quoted 3,000$ range for a rebuild. As for the junktpyard one, I payed 550$ dollars for it. If you are in a area with a lot of troopers, getting a donor would probably be best. As for your Trooper, I have the exact same year, however I have the dreaded auto... which was rebuilt before I got it.
1995 Trooper LS
Want to do:
96/97 cam swap
Rebuild heads
Injector Swap
new exhaust
New suspension everything
SuperTroop95
Mi Amigo
Postby snoozer » Sun Mar 12, 2017 11:46 pm
Finding a used engine, from a donor or otherwise, sounds like a good plan to me.
snoozer
Postby Ricky » Thu Mar 16, 2017 3:37 pm
I almost bought that truck! However my boss shot down the idea of me pulling apart another car in the warehouse at work. You totally scored it's very clean, and the seller seemed like a decent dude. If you go on row52.com you will find listings for pick a pull yards. I just pulled the center console to match my manual swap from a 2nd gen trooper last weekend. It's over at the pull and save in Phoenix off of 27th ave and buckeye. It's the exact same truck as yours. I believe they sell used engines for $299 with a warranty. If you don't want to pull it yourself I have a number for a guy who pulls parts in that yard. I forgot what he charged me to pull the manual trans for my rig, but it was super reasonable. He also kept all of the fasteners, clips etc.. BTW any chance you want to sell the aisin manual hubs?
Ricky
Postby P-tricky » Mon Mar 20, 2017 5:01 am
Thanks for the advice, all.
Update: the engine and transmission are out, hopefully we will have a donor in the next week or two to make the swap. It wasn't the easiest to work on, but definitely easier than either of the Subarus I used to own. It also helped that my buddy who used to work as a mechanic brought all his air tools over.
Ricky wrote:I almost bought that truck! However my boss shot down the idea of me pulling apart another car in the warehouse at work. You totally scored it's very clean, and the seller seemed like a decent dude. If you go on row52.com you will find listings for pick a pull yards. I just pulled the center console to match my manual swap from a 2nd gen trooper last weekend. It's over at the pull and save in Phoenix off of 27th ave and buckeye. It's the exact same truck as yours. I believe they sell used engines for $299 with a warranty. If you don't want to pull it yourself I have a number for a guy who pulls parts in that yard. I forgot what he charged me to pull the manual trans for my rig, but it was super reasonable. He also kept all of the fasteners, clips etc.. BTW any chance you want to sell the aisin manual hubs?
Hmmm, that pick and pull might be a good route, but I'm still leaning toward buying a complete donor so that we can make some of the cost back by parting it out. the PO was definitely a good dude, but if he had manual hubs for it I didn't get them (otherwise they'd be going on-- the auto hubs were already a problem when we were pulling the transmission). The truck is in really good shape aside from the engine. My partner spent most of this weekend detailing the interior and now I have trouble believing that it's 22 years old.
1995 Trooper, Manual Transmission
P-tricky
Postby P-tricky » Fri Mar 24, 2017 6:29 pm
Picked up a donor today. 2wd 1995 rodeo with the 3.2. 136k miles, runs well, but the body and interior are in kinda rough shape and the transmission is very dead. $340 delivered to my driveway by the previous owner. We'll only be keeping the engine, so if you want parts, let me know.
P-tricky
Postby DSUZU » Fri Mar 24, 2017 9:33 pm
And you can probably recoup some of that money selling parts from the Rodeo here. Dennis
Has thanked: 216 times
Have thanks: 619 times
Postby P-tricky » Fri Mar 24, 2017 10:20 pm
That's the idea. I'll get a classifieds post up on here soon.
P-tricky
Postby P-tricky » Thu Apr 27, 2017 2:17 pm
The engine compartment in a Trooper is pretty tight. According to the service manual, to pull the engine you first have to pull the transmission. The bolts connecting the two were pretty darn tight.
We did not have a transmission jack at this point, so getting it out was a team effort.
Lowering the transmission with a floor jack and three people stabilizing it was not fun. 2/10, do not recommend.
By the end of the day we were ready to pull the engine. It's very easy to get air tools on the motor mount bolts when there are no heads on the engine. Unfortunately, the engine was disassembled to the point that the hangers were no longer attached, but we had a pile of head bolts, so we attached the chains from the engine hoist to those and yanked it right out.
P-tricky
Postby P-tricky » Thu Apr 27, 2017 2:28 pm
Next project: prepare the donor to pull the engine.
We decided that it would be easier to get the engine and transmission out as one unit, but to do that, we had to take a sawzall to the body.
Comes right out!
P-tricky
Postby P-tricky » Thu Apr 27, 2017 3:04 pm
Having the engine and transmission out made it much easier to remove the bolts between them. Air tools are magic.
While it was out, we replaced the timing belt, water pump, head cover gaskets, common volume gasket, and clutch.
One note: remember to put the lower bellhousing cover on BEFORE the flywheel. we had to take the clutch back off after putting the engine in to put that in place.
P-tricky
Postby P-tricky » Thu Apr 27, 2017 3:19 pm
IF YOU DO THIS SWAP, MAKE SURE TO CHANGE OUT ALL OF THE ACCESSORIES. The Trooper and Rodeo (of the same year, same engine), use a different alternator, starter and vacuum control location. We didn't change some things until after the engine was in and that was a massive pain in the neck.
From there it was mostly straightforward putting everything back together. The only real issue was the starter (turns out we forgot to attach the main grounding cable to the engine--oops!).
Once that was fixed, the engine fired right up and passed emissions testing on the first try. We are now on the road!
P-tricky
Postby Ricky » Wed May 03, 2017 2:31 pm
Nice work!!! Good to see you got it back on the road!
Ricky
Return to Drivetrain Problems
Users browsing this forum: Bing [Bot], muddingrodeo and 3 guests
