Old Member, but New 'Zu (to me)
Say Hi here for the first time. We're all friendly :)
Postby JoeIsuzu » Fri Nov 08, 2013 12:53 am
Just picked up a '94 Amigo today from some guy in Dacula, GA that we all know. :) My diesel P'up is currently in rehab, and I've always liked the 1st-gen Amigos. So I bought the Amigo, and it's now in my driveway.
Driving it home was a little exciting. I found out that it's possible to stop all three lanes of westbound traffic on I-20 coming out of Atlanta, and even get applause from other drivers. More on that later. :(
Pictures to follow.
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 73 times
Have thanks: 75 times
Re: Old Member, but New 'Zu (to me)
Postby JoeIsuzu » Fri Nov 08, 2013 9:59 am
So the left rear tire BLEW out at in the left-most lane, at about 75 mph in typical Atlanta-area traffic. Here's a photo of where the Amigo came to rest. I got it out of the driving lanes before taking this photo, but the hook-shaped gouge in the shoulder is from my left rear rim, from when it finally swapped ends right before coming to a stop in the inside lane. Those weren't the only skidmarks! :lol:
And here's the Amigo. I decided not to change the tire here. I waited about 15 minutes for a break in traffic, and limped over to the exit and got completely off the road.
Jack
IsuzuPup.com
JoeIsuzu
Postby BigSwede » Fri Nov 08, 2013 10:01 am
WHew, bet that got your heart going!
BigSwede
Has thanked: 14 times
Have thanks: 251 times
Postby JoeIsuzu » Fri Nov 08, 2013 11:31 am
BigSwede wrote:WHew, bet that got your heart going!
Yep. My legs were a little wobbly. When it finally came back down on all 3.5 tires, I was looking eye-to-eye with a guy in a Silverado. He gave me two thumbs up, applauded, and hollered "You did a good job!" All 3 lanes waited while I got out and checked to see if I had all 4 wheels still on the truck, then I got back in and pulled it onto the shoulder.
Jack
IsuzuPup.com
JoeIsuzu
Postby IsuzuGeek » Fri Nov 08, 2013 1:11 pm
That's scary. Reminds me of the time I was towing a car trailer in heavy Chicago traffic in the cold sleet and the trailer bounded off the hitch. Luckily, those little safety chains held true but it was QUITE a close call as the trailer went swinging into the other lanes and came to a stop on the shoulder.
Glad you are OK, and a good reminder to watch the tread on your tires.
Bart
IsuzuGeek
Have thanks: 197 times
Postby ubs_lover » Fri Nov 08, 2013 7:00 pm
Glad you're OK Jack.
So are you able to bring it home?
1995 Hi-Roof 1st Gen Trooper, 4ZD1, stock. viewtopic.php?f=15&t=64293
1983 SWB LUV, C190 KBD41 Diesel 4WD N/A, MSG4K 4spd Tranny viewtopic.php?f=15&t=61309
1984 SWB Isuzu Trooper, C223 Diesel N/A, MSG5E 5spd Tranny, AVM manual hubs, Michelin A/T 7.50r16 on 16" steel wheels. Sold. viewtopic.php?f=15&t=33232
1990 LWB Trooper, 4JA1 Diesel N/A, MSG5K 5 spd Tranny, AVM manual hubs, 33"x12.5" M/T on alloy wheels. Sold.
1984 LWB Trooper, C223 Diesel N/A, stock. Sold.
ubs_lover
Has thanked: 23 times
Have thanks: 74 times
Postby JoeIsuzu » Sat Nov 09, 2013 12:37 am
ubs_lover wrote:Glad you're OK Jack.
Thanks. Yes, it's in my driveway now. I'll be tire-shopping next week.
Jack
IsuzuPup.com
JoeIsuzu
Postby JoeIsuzu » Tue Nov 19, 2013 8:00 pm
I won't lie, I'm starting to like this little guy. I ordered a cheap stereo today, since I bought it without one installed. I spent a whopping $72.12 (including shipping). I'll post up the details once it's installed.
Jack
IsuzuPup.com
JoeIsuzu
Postby JoeIsuzu » Fri Nov 22, 2013 4:22 pm
The head unit is a cheapie, but it's got bluetooth, USB, and takes memory cards--just not discs. I installed it, but I don't like it in the factory location. I may swap it out with the heater controls. It's only half-depth, since it has no CD/DVD. I'll post photos when it's in its final location. Here's the unit:
Boss Audio Systems 810DBI In-Dash Single-DIN MP3-Compatible Digital Media Player
On another note, it's been raining the last couple of days. I am completely blown away by the difference having a limited-slip rear end makes. My P'up would easily spin on takeoffs and turns, but the Amigo stays locked in. Thanks to Jerry and Dan for the LSD!
Jack
IsuzuPup.com
JoeIsuzu
Postby JoeIsuzu » Fri Dec 06, 2013 7:33 pm
By the way, I've had this Amigo less than a month, and probably three people have asked me if I'd sell it to them. When my P'up is out of rehab, I just might keep the Amigo. But if not, it looks like it shouldn't be hard to sell. :)
Jack
IsuzuPup.com
JoeIsuzu
Postby Kenso » Fri Dec 06, 2013 9:24 pm
What are you having done to your pup? Is it a cosmetic rehab or mechanical?
95 Pickup
98 SLX
03 Disco
Kenso
Has thanked: 4 times
Have thanks: 6 times
Postby JoeIsuzu » Fri Dec 06, 2013 9:26 pm
Kenso wrote:What are you having done to your pup? Is it a cosmetic rehab or mechanical?
So far, mechanical. The engine is being overhauled, I'm having an '86 crankcase ventilation system added, etc. etc.
Once that's done, I need to find someone who will do a good job with some body work and paint. Then the interior...then maybe good for another 30 years.
Jack
IsuzuPup.com
JoeIsuzu
Postby Kenso » Fri Dec 06, 2013 11:45 pm
Sounds good! How many miles do you have on your pup these days? Was the engine getting tired or is it just a preventative overhaul?
95 Pickup
98 SLX
03 Disco
Kenso
Postby JoeIsuzu » Sat Dec 07, 2013 12:10 am
Kenso wrote:Sounds good! How many miles do you have on your pup these days? Was the engine getting tired or is it just a preventative overhaul?
It was running well, but had erratic oil consumption. I was never able to pinpoint the reason why.
Jack
IsuzuPup.com
JoeIsuzu
Postby Bi0mancer88 » Tue Dec 10, 2013 7:20 pm
Gotta love buying old vehicles. I had bought an 89 cherokee 3hrs away from my house, blew a transmission seal and clogged the highway with a thick plume of opaque white smoke. Where she went down was a dry county. Couldn't even get a beer while I waited for a tow truck.
Contact me for personalized edited photos of your ride, good wallpapers, or hung in a frame.
MY THREAD
http://forum.planetisuzoo.com/viewtopic.php?f=15&t=74135&p=652801#p652801
Bi0mancer88
Postby JoeIsuzu » Tue Dec 10, 2013 10:55 pm
Bi0mancer88 wrote:Gotta love buying old vehicles. I had bought an 89 cherokee 3hrs away from my house, blew a transmission seal and clogged the highway with a thick plume of opaque white smoke. Where she went down was a dry county. Couldn't even get a beer while I waited for a tow truck.
I didn't buy that one old at all. In fact, who said it's old?! It's still my new truck!
Jack
IsuzuPup.com
JoeIsuzu
Postby Bi0mancer88 » Wed Dec 11, 2013 12:06 am
Right, new to you. I wouldn't necessarily consider a 94 a new truck though.
MY THREAD
Bi0mancer88
Postby JoeIsuzu » Wed Dec 11, 2013 12:15 am
Bi0mancer88 wrote:Right, new to you. I wouldn't necessarily consider a 94 a new truck though.
Oh, I thought you were referring to my comment about oil consumption.
Jack
IsuzuPup.com
JoeIsuzu
Postby JoeIsuzu » Thu Dec 29, 2016 11:02 am
Update: I sold this Amigo to my oldest son in 2014 (?). It has been his daily driver until yesterday. He sold it to my younger son yesterday, so it's still in the family. Maybe someday it will come back to me. ;)
I just noticed, I never got around to posting pictures of this Amigo. I'll have to do that.
Jack
IsuzuPup.com
JoeIsuzu
Return to New Member Introductions
