Someone's "fix" for clutch bleeding
Postby DSUZU » Sat Jan 07, 2017 8:39 pm
Just came across this. I drove the vehicle and the clutch just barely releases. One more reason you need to find a competent mechanic or do it yourself. Dennis
Has thanked: 213 times
Have thanks: 594 times
Re: Someone's "fix" for clutch bleeding
Postby Ed Mc. » Sun Jan 08, 2017 1:16 am
That's a heck of a free play adjustment!! :shock:
'90 3.4 Troop LS;
Yes, I am a Trooper-Holic!!!
Keep On Troopin' !
Ed Mc.
Have thanks: 198 times
Postby geoffinbc » Sun Jan 08, 2017 8:37 am
On my friends Trooper we found the same thing. The issue was a ruptured diaphragm in the damper keeping air trapped. Removed damper and everything worked perfect.
Big Bore Intake Kits Here
geoffinbc
Has thanked: 2 times
Have thanks: 318 times
Postby DSUZU » Sun Jan 08, 2017 1:14 pm
This is an Amigo so no damper (although my '97 Rodeo had one). This is typical of a non-Isuzu experienced mechanic's fix. Honestly, on my '91 V-6 Trooper (manual conversion), the only way I could get the clutch to where I liked it was adding a washer on the slave rod between the ball and fork. And the damper was removed from that one. Dennis
Return to Drivetrain Mods
Users browsing this forum: Bing [Bot], deFaint and 4 guests
