2.6 throttle body swap mod
Postby DSUZU » Mon Jan 02, 2017 8:37 pm
2.6 2BBL to 1BBL throttle body swap. I know a few have done this. Anyone know a link to it? I have questions: what are the advantages? are there disadvantages? I believe the upper manifold drops on the original lower, is the rest of it plug and play? Do you have to swap the ECM too? What about an entire engine swap? I'm looking at a 1993 to swap onto my 1989. Dennis
Has thanked: 209 times
Have thanks: 588 times
Re: 2.6 throttle body swap mod
Postby DSUZU » Tue Jan 03, 2017 8:59 pm
Bump. Still looking for factual information on this. Seen a few things here and elsewhere, but no definite answers. Dennis
Postby Fox » Wed Jan 04, 2017 2:55 pm
It's a pretty straight forward swap. The entire upper manifold switches over to the lower intake manifold. Depending on what year injectors you have, you may have to use a few washers as shims to bolt down the injector rail.
I have a complete upper manifold and throttle body if you'd like it. Then you'd just need the 2.5" intake tube.
Fox: the official Non-Forum Troll
Have a question? Things I have first hand experience in.
'91 Amigo : fresh 2.6L 4ze1 . Hybrid rhb5 Turbo . Delta 260 camshaft . 59.5" Wide Track & Big brake front suspension . BJ flip&space . Lokka's front/rear . 31" BFG M/T Km2
I machine parts. BJ spacers, EGR plates, Alignment shims, etc.
For this post the author Fox was thanked by:
Fox
Super Trooper
Has thanked: 8 times
Have thanks: 10 times
Postby DSUZU » Wed Jan 04, 2017 4:55 pm
Thanks. Actually have a complete vehicle and contemplating the swap, but didn't know if ECM or wiring needed to be swapped. Noticed that donor vehicle, a 1993, has a 2 wire O2 sensor, but that is just heated and I was planning a heated mod anyway. Dennis
Postby kg4miq » Wed Jan 04, 2017 4:59 pm
Dennis,
This is an easy swap for you. There are two different 1BBL intake manifold plenums, however. One has an electric EGR (CAL emissions??) and the other is vacuum-operated (FED emissions). You want the vacuum-operated one, as it's a larger diameter throttle body. The only thing I had to do was drill and tap the inlet tube fitting for the EGR transducer (I chose to keep the EGR circuit intact). Just be sure not to drill TOO deep: if you do, the tube will remain loose, once the fitting is screwed into the upper plenum. A bottom tap helps thread this all the way down and get enough thread purchase to prevent the fitting from stripping. The lower plenum stays on the engine - no need to remove it. Might be a good opportunity to replace or clean the fuel injectors, as they're easy to get to, once the upper plenum and throttle body are removed.
One other thing I had to do was bend the lower throttle body bracket for the throttle cable to attach to it. I used the bracket from the original 2BBL throttle body and bent it to shape in a vise. Had to do a little bit of grinding to trim the edges and make it fit the two lower holes for the new throttle body. Once the bracket is shaped like you need it, the throttle cable should line up fairly well. I don't recall having to swap throttle cables.
No need to swap ECM or anything, as the computer has enough programming ability to compensate for the increased airflow. I did swap the intake piping and air filter housing, also, which required a little bit of work to get the plastic intake pipe to line up well. I remember rotating the plastic portion a bit, in order to make the air hoses line up enough to connect to the thermal valve on the thermostat housing and the oil vent pipe on the back of the valve cover. IIRC, I had to rotate the plastic intake pipe so the piece of tubing going to the valve cover ended up pointing up toward the hood of the truck.
Fox's comment above about the fuel rail may be a factor, if you've only got one style of fuel rail, as they are machined slightly differently and fit to the intake manifold a bit different, but this is only if you choose to use different injectors. I don't recall swapping the fuel rail.
Once it was done, Jerry saw it at a Trooper get-together down in Greenville and said it was one of the nicest running four-cylinder Troopers he'd seen. I didn't have a Jerry cam at the time, but that would've also helped. I think the '93-97 cams are close enough to Jerry's grind to make for a really peppy engine, though. If you've got the later cam, you'll be fine.
I don't currently own the vehicle, but I can still get pictures of the swap, if you'd like. Might take a bit for me to coordinate, but I don't foresee a problem.
/tim
How to rebuild a 2.6L 4ZE1 distributor
'92 Pickup - "Blacktail" - 4ZE1
'89 SE Trooper - "Vader" - 4ZE1
'89 Pickup - "Wicket" - 4ZD1
'90 S Trooper - "Nan" - 4ZE1 (possible V8 swap - Ford 302 with 5 speed?)
For this post the author kg4miq was thanked by:
kg4miq
Has thanked: 21 times
Have thanks: 58 times
Postby Ed Mc. » Wed Jan 04, 2017 6:08 pm
Sounds like the really hot mod would be an entire '94+ head along with the '94+ induction system including 1-bbl round TBI, bolted to an earlier 2.6 for a nice bump in compression.
Plus a "Jerry Cam" if it indeed is "hotter" than '94+ cam. Otherwise as you suggested just use the '94+ cam.
No doubt Jerry could describe the difference between the 2 cams.
'90 3.4 Troop LS;
Yes, I am a Trooper-Holic!!!
Keep On Troopin' !
Ed Mc.
Have thanks: 188 times
Postby kg4miq » Wed Jan 04, 2017 6:32 pm
Yes, Ed, that would be the way to go, except the fuel injectors for the '94+ are different than the earlier ones. The resistance is higher on the later ones (Jerry can give specific numbers), and the ones on the CAL emissions version (electric EGR) are even more different (similar to the Impulse injectors).
While it's not that difficult to rewire for the newer injectors, the ECM may have to be swapped for that, in order to match the impedance correctly.
EDIT: Dennis, I noticed you asked about advantages and disadvantages...
The 1BBL has 14% more airflow through it than the 2BBL version, per Jerry. It's also easier to adjust the idle set screw, since it's right on top. ECM easily compensates for the higher airflow without changing injectors.
The only disadvantage I can think of is the hassle of swapping it, and being careful not to drill the EGR transducer port too deeply (ask me how I know).
HTH,
/tim
kg4miq
Postby Ed Mc. » Wed Jan 04, 2017 7:19 pm
Tim, looks like the injectors are physically different, too, and would not interchange. So that kinda messes things up!
Are the intake ports of the newer head different than the older?
I pulled up the intake manifold gasket set for a '94 Amigo 2.6 and '90 Trooper 2.6 and they are the same - FEL-PRO MS936571.
That would lead me to believe you could bolt the later upper intake and the earlier lower intake to the '94 head and use in in an early 2.6.
If not, that's a good discussion into the differences between old & new.
'90 3.4 Troop LS;
Keep On Troopin' !
Ed Mc.
Postby DSUZU » Wed Jan 04, 2017 7:45 pm
Many thanks for all the replies. This is the very reason I LOVE this site and also why a good portion of my 6,000 posts exist - helping when I can. Great to receive help, which brought me here in the first place. Dennis
FWIW, IIRC, ALL the 2.6s share the same gasket set and it comes with both round and "oval" throttle body gaskets (at least the Felpro ones I have seen)
Postby Ed Mc. » Wed Jan 04, 2017 8:27 pm
I found a few pics, one is of the intake ports of an AMC replacement head with small combustion chambers, and stated as a replacement for '88-'97 2.6 heads.
And a shot of the combustion chambers where you can see how they differ from the early-style's completely round chambers.
The other is a poor-resolution pic of an earlier 2.6 head's intake ports.
The intake port configuration looks to be identical and I'd think that the intake gasket should fit either.
Thoughts?
'90 3.4 Troop LS;
Keep On Troopin' !
Ed Mc.
Postby Fox » Wed Jan 04, 2017 8:51 pm
I've used both upper plenum on my turbo amigo, but went back to the two barrel throttle body. It had better response with the turbo.
Fox
Super Trooper
Postby kg4miq » Wed Jan 04, 2017 11:57 pm
Ed Mc. wrote:Tim, looks like the injectors are physically different, too, and would not interchange. So that kinda messes things up!
Ed,
That is correct, the injectors are different and the ports they mount into on the intake manifold are a different size than the older 2BBL intake. Not sure if the newer injectors have a higher flow rate, but I know they have three ports in the nozzle with a definitive spray pattern, and no exposed pintle, like the older injectors have. They are not interchangeable, but the upper plenum is easily swappable, so the benefit of higher air flow can be realized using the 1BBL throttle body, but retaining the older lower plenum. It's a great combination, with relatively little effort. I'll try to get some pics up comparing the two in good lighting.
On a related note, there are two distinct versions of the 1BBL throttle body, with the smaller one being the CAL version with electric EGR, which is why I advised against it. The camshaft, however, from that version is the improved, later design, and provides a bit of extra torque, so it can be easily swapped into the earlier engines with no trouble.
Unfortunately, even the 1BBL throttle bodies mount differently to the upper plenum, so they are not interchangeable, either. I have had both versions here at one time or another, and mistakenly purchased an engine with the electric EGR and smaller throttle body early on, so it's been sitting on a shelf taking up room for quite some time now. I get the feeling it seems to be GM's misguided attempt at redesigning the four-cylinder intake to use their parts (MAP, rather than MAF, for instance) and really didn't improve on the overall design whatsoever, as compared to the true Isuzu-developed 1BBL intake, which utilized the simple vacuum EGR and no GM parts, and backwards-compatible lower plenum which uses the smaller injector ports.
The CAL version really is a separate entity, as far as the intake is concerned, and doesn't provide much for modification purposes, unless someone knows of a vacuum-operated EGR which will fit the electric EGR port, in which case, this intake might actually become usable after all. The rest of the engine, however, is very much worth having, since it has smaller combustion chambers and pistons to match, and improved camshaft.
Ed Mc. wrote:... That would lead me to believe you could bolt the later upper intake and the earlier lower intake to the '94 head and use in in an early 2.6.
That's exactly what I did with the one I modified. Newer upper plenum, older lower plenum, older throttle cable bracket shaped to fit, EGR port tapped and threaded on the upper plenum, and 1BBL throttle body with intake piping and MAF.
HTH,
/tim
kg4miq
Postby kg4miq » Fri Jan 06, 2017 4:15 pm
Found a picture of the smaller 1BBL throttle body and upper plenum with electric EGR. This is NOT the one you want, but it did trigger a memory of possibly having to splice in a connector for the throttle position sensor to match the older circuit, since I think the TPS connector is the small, round, three-wire version shown in the photo. The throttle body in the photo has an electric idle air control (IAC) mounted on it as well, which makes this version unusable for the conversion.
kg4miq
Postby kg4miq » Fri Jan 06, 2017 4:26 pm
HERE is the correct plenum and throttle body for this conversion, and no, I didn't have to splice the newer style throttle position sensor into the circuit. It would have been a different design - rather than a simple three-position switch type, the one in the previous photo is a typical GM-style, variable resistor TPS.
This one is the older style Isuzu three-position switch TPS (idle, off-idle, WOT).
kg4miq
Postby kg4miq » Fri Jan 06, 2017 4:47 pm
DING, DING, DING! Winna', winna', chicken dinna'! Found a great write-up with pictures on here.
2BBL to 1BBL conversion (plus turbo)
Later down in the write-up, he gives a closer picture of the EGR transducer piping drilled and tapped, but it appears to me to be too deep, which prevents the pipe from locking into position as the nut around it is tightened down. I wouldn't drill it quite so deep, Dennis.
I'd love to do something like this, but with twin Webers. I know there was something similar years ago for the Chevy Luv, as my friend had one, but I haven't seen one since.
DSUZUMarkB.NV
kg4miq
Postby DSUZU » Fri Jan 06, 2017 5:08 pm
Thanks again Tim. Yeah, teh big question was involving the "hole" and not to go too deep. I imagine it will become more clear on disassembly. More tham likely, I'll just swap the entire manifold - or entire engine. The dual webers was something that crossed my mind the first time I separated a manifold. Another thought was build a low profile "box" plenum and put a 4bbl on there - might need more of a cam to do that though. Dennis
Postby Ed Mc. » Fri Jan 06, 2017 6:14 pm
It's kinda hard to see just how much more surface area the 1-bbl throttle body has, just by looking at the old & 2 side-by-side.
But check out these pics of the old & new MAFS. The difference is MASSSIVE!
Obviously this is THE mod for an older 4ZE1. Even with a stock engine you should notice a huge difference in performance.
Add more things like cam, header, and exhaust, to move even more air thru the engine, and you've raised performance to yet another level.
Makes me want to look for a nice, clean 2.6 Trooper and have at it!
I'd probably look for an automatic so my daughter could drive it in a pinch. Cause she ain't driving a stick, ever! :roll:
'90 3.4 Troop LS;
Keep On Troopin' !
Ed Mc.
Return to Drivetrain Mods
Users browsing this forum: Bing [Bot] and 1 guest
