TOD deleat
TOD deleat
Postby garyauto764 » Wed Dec 28, 2016 2:19 pm
First time posting hopefully no errors i have a 2000 v cross with TOD problems i would like someone to renew the link to tod delete.
thanks in advance
Gary Otto
garyauto764
Re: TOD deleat
Postby Buster28 » Thu Dec 29, 2016 11:56 am
It was not a TOD delete, the modification changed the magnetic clutch wiring causing it to send constant 50% torque to the front prop shaft when TOD (4WD Hi) is selected so it functions like non TOD 4WD similar to a Rodeo. I may have the schematic if your still interested.
02 Rodeo Sport 4X4 3.2L V6
Have thanks: 824 times
Re: TOD deleat
Postby garyauto764 » Thu Dec 29, 2016 12:26 pm
very interested its a nice clean truck bought the oem manual what a night mare ive read you can fix it and it will quit working shortly after
thanks all for the help
garyauto764
Re: TOD deleat
Postby Buster28 » Fri Dec 30, 2016 8:58 am
Re: TOD deleat
Postby garcian1 » Tue Jan 10, 2017 10:17 pm
Have you tried just jumping the vacuum line to switch it over?
garcian1
Re: TOD deleat
Postby Buster28 » Thu Jan 12, 2017 8:26 am
garcian1 wrote:Have you tried just jumping the vacuum line to switch it over?
TOD is not vacuum controlled.
Return to Drivetrain Mods
