4JB1 Repair and Swap into Amigo
Re: 4JB1 Repair and Swap into Amigo
Postby mudoilngears » Fri Oct 28, 2016 1:25 pm
Dropped off the engine at the machine shop today! Supposed to have a verdict by afternoon.
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, more mods to come!
Build in progress...
mudoilngears
Has thanked: 12 times
Have thanks: 64 times
Postby Dingbat » Fri Oct 28, 2016 3:43 pm
mudoilngears wrote:
Dingbat wrote:Did you need to undo the big crank bolt to get the 3 v-belt pulley off the crankshaft ?
Sorry I didn't get back to you on this. I checked and you only have to remove the four small bolts to remove the balancer.
No worries, thanks.
1997 UCS7VF (Rodeo / Passport / Frontera)
Wry Wench build thread
3-inch Calmini Lift Kit, Indy4x 1.5-inch Leaf Lift
Dingbat
Have thanks: 61 times
Postby mudoilngears » Wed Nov 02, 2016 4:00 pm
So I talked to the machine shop today...
The good:
The head is fine, not cracked or warped, just needs new valve guides.
The crank just needs to be ground to .10 over.
The Bad:
He says he can't be completely sure until he takes out the old sleeves, but it looks like the block deck was resurfaced at an angle, and that is what was causing the original owners problems.
The oil pump is not putting out full pressure, so it need to be replaced.
Need new liners, pistons and bearings of course, plus the gasket set and everything else needed for an overhaul...
Machine shop costs are going to be $500 wish, ouch!
mudoilngears
Postby JoeIsuzu » Thu Nov 03, 2016 11:27 am
You may want to check this out:
viewtopic.php?f=13&t=24475&p=804993#p804993
Jack
Original owner, 1983 Isuzu P'up LS Diesel. Engine overhauled by JLEMOND. Ready for new paint now!
1994 Isuzu Amigo 2wd
IsuzuPup.com
"There are no dumb questions"?! Maybe not...
but there are smart ways to ask. Old, but classic:
How To Ask Questions The Smart Way
JoeIsuzu
Has thanked: 73 times
Have thanks: 76 times
Postby mudoilngears » Sat Nov 12, 2016 9:36 pm
JoeIsuzu wrote:You may want to check this out:
Jack
I am many thousands of miles away, and even if I weren't, that would be far more expensive than rebuilding what I have. Besides that's an industrial engine. Injector pump and who know what all elae is different.
mudoilngears
Postby JLEMOND » Sun Nov 13, 2016 7:01 pm
gruff54 wrote:Joe,
I'll take a look at mine, if you'd like. Wouldn't the number on the bellhousing would be a casting #? Would that be the same as the part #?
Mike
MIKE CASTING NO WOULD ONLY TELL YOU IT IS THE SAME AS ANOTHER ONE JUST LIKE IT. WOULD NEED A PRINTED PT ,NO JUST CHECKED THAT PT NO 898 047 2300 AND IT CAME BACK AS NOT RECOGNIZED , DOESNT MEAN IT IS NT A GOOD NO , JUST NOT A U.S SOURCED NO , SO IT MIGHT TAKE A WHILE TO GET ONE.
JLEMOND
Have thanks: 247 times
Postby mudoilngears » Sun Nov 13, 2016 7:12 pm
This is what was on the box Jerry, don't know if it helps you figure anything more out. I would say to anyone, wait til I get it intalled for sure on the transmission. I'm 99.999% sure it fits, but I haven't been able to try it on the transmission side yet. It fits the engine perfectly.
mudoilngears
Postby bradzuzu » Thu Nov 17, 2016 2:31 am
mudoilngears wrote:So I talked to the machine shop today...
The good:
The Bad:
Hopefully everything works out , it didn't look like the Pistons or liners had been changed out ..
You could open up the oil pump and inspect it , the pressure relief can be shimmed up if it checks out ..
Has thanked: 209 times
Have thanks: 369 times
Postby mudoilngears » Mon Dec 19, 2016 3:12 pm
Well! Christmas plot twist!
Look what got dropped off yesterday!
I picked up the engine parts from the machine shop on thursday, and went and took a look at this Rodeo. The engine is in pieces, but the body and frame are pretty near perfect for its age. I made the fellow an offer, which he accepted.
It's a 98 LS Manual transmission, with an LSD in the rear axle.
So, the diesel will go into this now, and the Amigo, sadly, has to go,ASAP...
mudoilngears
Postby bradzuzu » Tue Jan 10, 2017 1:36 am
Noooo !!! Ditching the amigo ?? I'm so not happy about this news ...
Postby mudoilngears » Tue Jan 10, 2017 12:58 pm
bradzuzu wrote:Noooo !!! Ditching the amigo ?? I'm so not happy about this news ...
Me Neither really...
I'd like to keep the Amigo really, but I can't afford it.
mudoilngears
Postby bradzuzu » Thu Mar 09, 2017 1:01 am
Seems we are all changing things up :)
How's everything been going ?
Postby mudoilngears » Thu Mar 09, 2017 4:39 pm
Yup, unfortunately our vehicles change. I'm looking forward to seeing your Trooper take shape. The Rodeo is up and running. I have a lot of pics and story to upload, but I've been really busy lately.
mudoilngears
Postby bradzuzu » Thu Mar 09, 2017 11:51 pm
Well atleast you made time to give us an update :)
Return to Drivetrain Mods
