John's Auto to Manual MUA5 Transmission Swap
Re: John's Auto to Manual MUA5 Transmission Swap
Postby RamAirZ » Fri Apr 13, 2012 8:37 pm
It's the same AR5 as in the Solstice and Colorado etc with minor differences. They used the 4l30e in your trooper too, so I don't think the being paired with the modified 12bolt and possible v8 is a good argument lol. The AR5 imo is a smoother, quieter transmission, that would be my guess for its use.
Current: 2004 GMC Sierra- slightly modded, baja style :twisted:
2002 Isuzu Rodeo Sport- 3.5 swap, 3.5" lift, 32's, LED pods, custom exhaust
Previous: 1999 Isuzu Vehicross/1997 Isuzu Rodeo/ 1995 Honda Passport
RamAirZ
Have thanks: 27 times
Postby Hatfield » Sat Apr 14, 2012 2:23 am
RamAirZ wrote:It's the same AR5 as in the Solstice and Colorado etc with minor differences. They used the 4l30e in your trooper too, so I don't think the being paired with the modified 12bolt and possible v8 is a good argument lol. The AR5 imo is a smoother, quieter transmission, that would be my guess for its use.
I know, and from what I've read most like them and they hold up to LS swaps. Just curious to your reasoning behind the MUA5 being stronger.
2000 Trooper - AR5 swap, 4.77s w Aussie & ARB, TeraLows, 285/75 Goodyear MTRs,
Indy4x bumper, OME lift with N85 shocks, 1" BL, TG sliders, M8000, 20" LED, dents
1999 Trooper - parts car or future crawler
2007 Acura TL Type S - the daily
1995 Nissan 240sx - the racecar
Hatfield
Have thanks: 24 times
Postby RamAirZ » Sat Apr 14, 2012 9:23 am
Forgot to mention that the MUA5 has an integral tcase where the AR5 has a removable one, so it could have been to help with production since the auto tcase could be used for either transmission unlike before with the MUA5, and by full manual I mean the Tcase on the 95-earlier ones don't have a shift motor or anything like the later ones. You could use the 95-earlier auto case behind your AR5 to make it full manual. The AR5 will hold up to a stock LS swap on street tires, sticky tires and a good clutch and they won't. I'm just basing this on what I've seen between the failures on both. Mind you most of my AR5 opinions come from the LS swap stuff, but I've seen the MUA5 behind some turbocharged Isuzu's before making tons of power as well. I think that's what the turbocharged truck over in Australia is running and it's making a ton of power on a 6VD1. It's probably 6 in one half-dozen in the other
RamAirZ
Postby clutchcargo87 » Mon Oct 08, 2012 10:30 pm
hey, great write up! i'm half way through my swap and ive run into some trouble, my truck wont turn over. no tranny in yet, just tried to fire it up because its been sitting for a while. my mode selector switch is still intact (has 8 wires, not 4?) and the cable shift indicator is in the correct position. any idea what might be keeping my truck from starting?
1997 trooper 3.2L auto, 285/75/16 toyo open country m/t's on black d windows, some plastic trimming, snorkel
clutchcargo87
Postby RamAirZ » Mon Oct 08, 2012 10:42 pm
Neutral safety, you need to bypass the wires underneath on the mode selector. It's tied into the shifter, it will keep you from starting it with shifter removed even if the selector underneath is intact
RamAirZ
Postby clutchcargo87 » Mon Oct 08, 2012 10:57 pm
i thought of that, so i rotated the mode selector switch to simulate the truck being in park and still nothing. right now the switch is taken off of the auto and hanging under the truck. im going to try the bypass tomorrow after work and see if it works. i felt my heart sink when i turned that key and nothing happened, after all the time and money ive dumped into this thing. ill post again with my findings tomorrow.
clutchcargo87
Postby RamAirZ » Mon Oct 08, 2012 11:12 pm
Is the shifter out of it
RamAirZ
Postby clutchcargo87 » Mon Oct 08, 2012 11:17 pm
ya, shifter is out and there is no transmission in the truck, i put the shifter assembly on the floor and plugged the 2 connecters back into it and positioned the cable as if it were in park
clutchcargo87
Postby RamAirZ » Mon Oct 08, 2012 11:30 pm
Did you hook up the cable that runs to the steering column? Hook everything back up and see what it does
RamAirZ
Postby clutchcargo87 » Tue Oct 09, 2012 6:53 pm
WOO HOO!! it fired up! the other end of the mode selector switch wiring harness had come unplugged (under airbox) when i took the auto tranny out. thanks for the help, i appreciate it!
clutchcargo87
Postby RamAirZ » Tue Oct 09, 2012 7:13 pm
Figured something was unplugged lol, glad you got it
RamAirZ
Postby calebduff1 » Sun Nov 11, 2012 10:03 pm
im looking to do an automiatic 2wd to manual 4wd swap. (i know bad idea but im crazy and want to go for it) other than the axle and all that how would it differ from this? is there any extra wiring or anything?
01 Rodeo,
exhaust, intake, dual battery, 41/2" lift, 265/70r16 falken ATs,
2WD BUT CAPABLE!!!!
build thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=59442
calebduff1
Location: Laramie, Wyoming (school) Oak view, Ca (hometown)
Has thanked: 13 times
Have thanks: 10 times
Postby maynorpineda1 » Tue Nov 13, 2012 9:08 pm
did you get a new drive shaft??????
maynorpineda1
Postby jwood1016 » Thu Nov 15, 2012 8:24 pm
maynorpineda1 wrote:did you get a new drive shaft??????
yea. Longer for the rear, shorter for the front.
John
2002 Trooper
3 inch lift and 33's
jwood1016
Have thanks: 17 times
Postby Med!c » Tue Dec 04, 2012 11:53 pm
Healthy gear wine(ie. not from worn parts) is music.
00' Trooper 4x4- V6 3.5L
5-Speed Manual Aisin AR-5
Isuzu 12-Bolt Modified LSD
Isuzu 10-Bolt Aussie Locked
BGF AT T/A KO 285/75/16
Miss my old rodeo.
Med!c
Have thanks: 86 times
Postby 94rodeo94 » Sun Dec 30, 2012 6:51 pm
will this be the same swap for a 94 rodeo 3.2 auto to manul
94rodeo94
Postby RamAirZ » Sun Dec 30, 2012 10:23 pm
Pretty much. Firewalls are basically the same etc.
RamAirZ
Postby 94rodeo94 » Tue Jan 01, 2013 11:15 pm
what are the basic things i would need to start nd finish swap also will i need to chancge the tcm or ecm
94rodeo94
Postby RamAirZ » Tue Jan 01, 2013 11:47 pm
No you don't need to change, just need to either add a clutch switch in place of the neutral safety switch or bypass it. You'll need the transmission, flywheel, clutch, throwout bearing, clutch master and slave cylinder, some wiring etc etc. It's all mentioned in this thread
RamAirZ
Postby maynorpineda1 » Wed Jan 02, 2013 1:42 pm
hello, what did U do with the electric wires that I see in the pics???? I'm doing the same job and the truck does not start, It was automatic and I made it manual transmission, Almost everything is done but it does not start, help plz...
maynorpineda1
Postby RamAirZ » Wed Jan 02, 2013 9:17 pm
There are 2 sensors on the drivers side of the tranny that won't be used as well as the mode selector switch. The speedo and 4wd indicator switches use the same plugs from the auto harness so no wiring needed there. Now you will have to cut 4 wires off the mode selector switch to wire up your reverse lights and your clutch safety switch (if you use one). There is a white/green wire and a red/yellow wire, those 2 are for your reverse lights. You can wire them to the reverse switch in any order, the lights will work either way. Then is a black/white and a black/blue wire that are for your neutral safety switch. You can run these wires into the cab and install them on the clutch safety switch on the clutch pedal or you can just wire them together, but doing it this way will allow your truck to be started even if it's in gear and clutch isn't depressed.
Just copied the text, let me know if you need any more help
RamAirZ
Postby maynorpineda1 » Wed Jan 09, 2013 11:37 pm
I have some codes on my 02 rodeo 5 speed 3.2L (It has an automatic transmission) the codes are: P0753 and P1860 and there are automatic transmission codes. Like I said I swapped the transmissions and now it has a 5 speed manual transmission, I live in New Jersey, If the CHECK ENGINE LIGHT IS ON it will not pass inspection. HELP PLZ....
maynorpineda1
Postby RamAirZ » Thu Jan 10, 2013 12:28 am
Just saw your PM but you'll have to pull the bulb. That light is for the auto trans and since you don't have it anymore, it's gonna come on. Pull the cluster and remove the bulb or put a piece of electrical tape over it if you don't want to do that
RamAirZ
Postby maynorpineda1 » Thu Jan 31, 2013 2:43 pm
did U do any electrical job under the hood, and under the dash port????? if U did, what did U do it for????? Thank U bro.
maynorpineda1
Postby jwood1016 » Mon Feb 04, 2013 1:59 pm
Only electrical I remember was wiring in the reverse lights. Didn't touch anything else.
John
2002 Trooper
jwood1016
Return to Drivetrain Mods
