John's Auto to Manual MUA5 Transmission Swap
Re: John's Auto to Manual MUA5 Transmission Swap
Postby tovenaar » Sat Apr 02, 2016 11:44 am
So im thinking of doing a mua5 swap on my 01 rodeo sport 4x4
I'm wondering if there is an additional ground clearance gain with the mua5 ?
I see early in this thread the guy reused the original auto cross member flipped around but it sounds like he had to add a spacer to sit level and make the bolts fit. Would the mua5 cross member sit a bit higher ? Does the mua5 itself sit higher ?
Last time I was out where I shouldn't have been I found my t-case was the biggest clearance issue..thankfully it has a skid plate. Hoping the mua5 sits higher in the frame instead of below it ...
2001 Rodeo Sport V6 4x4 Automatic 205k
265/75 cooper adventurers , Indy torsion bars 2" cranked , 913's on 1" poly spacers , superwinch hubs
Bilstein rear shocks from a 4runner Bilstein front shocks ,rboth sway bars removed , rear brake line extension , custom rear bumper with swing out bicycle carrier , arb front bumper , 9500 lb Smitty built wenck, custom hi lift tire carrier , rear seat removed , custom sub woofer/lock box across rear foot well. JVC stereo , Sony explode speakers and an old 10" sub.
tovenaar
Postby Jaloro11 » Tue Jun 07, 2016 9:33 pm
Has anyone responded to your post at all. I'm looking to possibly do same thing with my 01 rodeo
Jaloro11
Postby tovenaar » Fri Jul 01, 2016 11:46 pm
No responses ......
tovenaar
Postby andy120 » Mon Jul 04, 2016 3:49 am
Did it have ABS in it before the conversion?
andy120
Postby totten » Mon Jul 04, 2016 5:30 pm
Really nice pics. and write up on swap. Great job !! JWOODS :twisted:
totten
Have thanks: 77 times
Postby Redman06 » Fri Sep 16, 2016 1:58 pm
Is the mua5 a pull or push type clutch?
Redman06
Has thanked: 2 times
Postby lorenzo816 » Tue Sep 20, 2016 9:39 am
I think John has been busy. But he has been on the board this month. PM him if you really want some answers on the swap
But to help a few of you....
pull vs. push clutch:
https://www.youtube.com/watch?v=Sf0g1BzkDjI
lorenzo816
Has thanked: 78 times
Have thanks: 50 times
Postby asghilo » Fri Jan 20, 2017 10:16 am
Redman06 wrote:Is the mua5 a pull or push type clutch?
MUA5 is pull clutch so make sure you get a quality kit w/ matching TO bearing so it doesn't pull out of the collar
1993 Trooper, 3.2L, 5spd
asghilo
Has thanked: 4 times
Have thanks: 41 times
Postby silverfox » Sat Mar 18, 2017 7:36 pm
So ive been reading this thread, i have a 2000 rodeo 4x4 and want to swap to manual...my local u pull it has a first gen rodeo with the manual i think its a 92 model but i dont remember. They also have a 97 trooper which is what i was interested in because of this thread but im somewhat confused about the transfer case...on johns he used the 95 because of less wiring and somewhere i read the 97 is different? Did i read that right and if so what electrical is different from johns swap? I was wanting to do the same swap because of all the info in this along with the awesome pics.
silverfox
Previous
Return to Drivetrain Mods
Users browsing this forum: Yahoo [Bot] and 3 guests
