John's Auto to Manual MUA5 Transmission Swap
Re: John's Auto to Manual MUA5 Transmission Swap
Postby jellis » Mon Feb 11, 2013 5:22 am
jwood1016 wrote:Only electrical I remember was wiring in the reverse lights. Didn't touch anything else.
what did you do with the park switch?
i cant work it out
jellis
Re:
Postby recon » Tue Apr 16, 2013 8:35 am
justwork wrote:
John's Tranny Swap
:lol: now thats funny 8) recon
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53703&hilit=evolution+of+my+truck
recon
Has thanked: 109 times
Have thanks: 47 times
Postby CREEPER » Wed May 22, 2013 9:43 am
Nice job! I absolutely REFUSED to buy an auto when I was looking for my trooper! I have driven 18 wheelers for 16 years, and I CAN'T STAND not having a clutch and shifter! There's just something about it....
CREEPER
Has thanked: 44 times
Have thanks: 12 times
Postby Dirtbikeguy2009 » Tue Jun 04, 2013 5:30 pm
How did you guys seal up the bellhousing on the manual Trans? To keep all the mud and debris away from the clutch.
2000 Isuzu Rodeo LS (117,000 miles) 5 speed swap. 3" suspension lift. 1" spacers. Flowmaster 40 series. Polk DB65, Kicker 07DS400, Apline Type R sub. 1,000 watt mono amp & 700 watt 4 channel amp. Black Painted Steel rims. Pioneer Appradio 3. Kensun HIDs with slim balasts and LED rear lights.
Dirtbikeguy2009
Has a Trail Truck
Has thanked: 2 times
Postby jwood1016 » Thu Aug 22, 2013 3:40 pm
Dirtbikeguy2009 wrote:How did you guys seal up the bellhousing on the manual Trans? To keep all the mud and debris away from the clutch.
Ummmmmm.....woops. :D
I imagine you could use the same stuff that you use to seal up the diff plate. But to me honest there is so much force on the clutch it would take a lot of mud.
John
2002 Trooper
3 inch lift and 33's
jwood1016
Have thanks: 17 times
Postby maynorpineda1 » Thu Oct 03, 2013 11:45 pm
hello buddy, how are you?????? I texted U before regarding by 02 isuzu rodeo that I made stick shift 5 speed. I have some problems, some codes p1860, p0753, that I did some research and it is suppost to be some errors with the torque converter (I MADE IT STICK SHIFT) IS THERE A WAY TO TRICK THE ECU???? PLZ HELP ........ THANK U
maynorpineda1
Postby maynorpineda1 » Mon Oct 14, 2013 11:41 pm
Hello did U get a MANUAL ECU?????? Im working on my isuzu 02 3.2L I put a 5 speed manual transmission ( it had an automatic transmission that was not working), my check engine light is on, I have problems with the torque converter which my TRUCK DOES NOT HAVE IT ANY MORE, WHAT SHOULD I DO? DO I NEED A MANUAL ECU TO FIX MY PROBLEM OR IS THERE A WAY TO TRICK THE AUTOMATIC ECU?????? HELP PLEASE........
maynorpineda1
Postby maynorpineda1 » Thu Oct 17, 2013 12:40 am
did U swap the ECU?? I have a problem with my truck, I made it stick shift (02 isuzu rodeo 3.2L 4 doors 6 cylinders, manufactured in jan 02) My check engine light is on. I live in New Jersey and the truck DO NOT PASS INSPECTION HERE, the codes the I get are P0758, P1860,0753, I did my research and IT IS THE TORQUE CONVERTER WHICH I DON'T HAVE ANY MORE. DO I HAVE TO GET A MANUAL PCM OR IS THERE ANY TRICKS TO FOOL THE PCM???????? HELP PLZZZZZZZZZZZZZZZZZ
maynorpineda1
Postby Med!c » Thu Jan 23, 2014 3:02 am
U need to swap the ECU for those codes to go away.
00' Trooper 4x4- V6 3.5L
5-Speed Manual Aisin AR-5
Isuzu 12-Bolt Modified LSD
Isuzu 10-Bolt Aussie Locked
BGF AT T/A KO 285/75/16
Miss my old rodeo.
Med!c
Have thanks: 86 times
Postby Ripah28 » Sun Apr 27, 2014 12:03 am
cool i need one of those swaps these autos are just crap
96 trooper
4" susp lift
285 guard dogs
HD tie rods
..................NO ROAD NO PROBLEM
Ripah28
Trail Scout
Have thanks: 9 times
Postby akamigo » Fri Jun 06, 2014 4:25 pm
I have A 99 amigo and a 92 second trooper with a 5 speed. Can i use the transmission from the trooper?
1999 Amigo,rebuilding and restoring 80k miles. mint condition....well almost.
1995 Trooper,SOHC,cold air intake w/K&N cone filter,functional hood scoop,2001 interior upgrades,wheel spacers,1600w stereo system,5 speed,4'' lift,1'' body,Skyjacker hydros,F-150 coils,35'' Cooper STT PRO MT,Aisin hubs,BJ flip/spacers,OME +3 shocks,dynomax muffler,no cat,no sway bars,indy hi-lift/spare tire mount,CB radio,4.56 gears,open diffs for now
akamigo
Postby Ruination » Wed Jul 09, 2014 3:48 pm
FYI - I am realizing more and more that the AR5 is a great transmission but it's known for synchros getting eaten up in the roadsters. (probably from a crapload more shifting than the trucks) not to mention the short throw and faster shifts doesn't help.
It's a strong unit though.. Many putting down 400+ HP at the wheels on the sky/solstice seem to be reasonably happy with them aside from the synchros making it "shift like a truck" as they say lol
1992 Isuzu Pickup w/some mods
1999 Mitsubishi Montero fully loaded
2008 Saturn Sky Redline
Ruination
Have thanks: 56 times
Postby akamigo » Wed Jul 09, 2014 5:52 pm
what is the AR5 found in?
akamigo
Postby Rhodes » Wed Jul 09, 2014 6:01 pm
akamigo wrote:what is the AR5 found in?
Troopers, assorted GM's.
89 Trooper, 2.8/5 spd. I NEED TWO 15" SNOWFLAKE WHEELS FOR THIS
Rhodes
Have thanks: 54 times
Postby akamigo » Thu Jul 10, 2014 9:11 pm
so the i better check on the 1992 trooper I'm getting and see what has as far as a 5 speed. Mau5 or Ar5...an codes to look for?
akamigo
Postby Rhodes » Sun Jul 13, 2014 9:10 am
I think the AR5 was used later than '92 (someone correct me if I'm wrong), pretty sure a 92 would have the MAU5.
Rhodes
Postby BigdaddySD » Thu Oct 16, 2014 4:46 pm
Pretty sure the AR5 is 98+ on Troopers. Not sure on Amigo's.
BigdaddySD
Postby BigdaddySD » Thu Oct 16, 2014 4:48 pm
Question: I'm considering a 5 speed swap on my truck. Before I start gathering parts, I'm wondering if this thread would be a good guideline, or if my 2001 trooper would be different enough that it wouldn't be a good guide.
BigdaddySD
Postby maynorpineda1 » Tue Oct 21, 2014 2:28 pm
hi U doing buddy. I have a question for U, I converted my isuzu rodeo 3.2L automatic to 5 speed manual REAR WHEEL DRIVE. IS THERE A WAY TO MAKE MY RODEO 4X4???? WHAT PARTS DO I NEED?????????? HELP PLEASE..........
maynorpineda1
Postby SRGtwitchy » Thu Dec 11, 2014 1:02 pm
would this be the same as if doing it on a 94' trooper using parts from a 95' im not to sure how much different amigos are other than overall length
94' is my good one (auto) and tranny is not good 95" is a parts truck (manual) engine and tranny no good
I have a rebuilt mua5 as a spare and its ready to go
SRGtwitchy
Postby JALinker » Mon Jan 19, 2015 10:56 am
OK-- curiosity--
I have an 88 Trooper and a 98 Trooper... both LWB...
The 88 is a 2.6l manual, the 98 is a 3.5l auto...
Can I swap the manual into the 98 and the auto into the 88? Or would I be better off sourcing the parts all separate?
I don't plan on keeping the 88 much longer, but want it to be a driver when I sell it.
JALinker
Postby lorenzo816 » Mon May 11, 2015 12:53 pm
Hatfield wrote:
RamAirZ wrote:It's the same AR5 as in the Solstice and Colorado etc with minor differences. They used the 4l30e in your trooper too, so I don't think the being paired with the modified 12bolt and possible v8 is a good argument lol. The AR5 imo is a smoother, quieter transmission, that would be my guess for its use.
I know, and from what I've read most like them and they hold up to LS swaps. Just curious to your reasoning behind the MUA5 being stronger.
RamAirZ wrote:Forgot to mention that the MUA5 has an integral tcase where the AR5 has a removable one, so it could have been to help with production since the auto tcase could be used for either transmission unlike before with the MUA5, and by full manual I mean the Tcase on the 95-earlier ones don't have a shift motor or anything like the later ones. You could use the 95-earlier auto case behind your AR5 to make it full manual. The AR5 will hold up to a stock LS swap on street tires, sticky tires and a good clutch and they won't. I'm just basing this on what I've seen between the failures on both. Mind you most of my AR5 opinions come from the LS swap stuff, but I've seen the MUA5 behind some turbocharged Isuzu's before making tons of power as well. I think that's what the turbocharged truck over in Australia is running and it's making a ton of power on a 6VD1. It's probably 6 in one half-dozen in the other
The 'box' that holds the gears is AISIN on the AR5 and is what numerous makers use.
GM but most importantly Toyota uses them too. The only major difference is the bellhousing pattern to the engine, the input shaft length and splines and obviously the tail shaft plate (for tcase)
The R150 and R151 are the same boxes as the AR5 just slightly different gear ratios and some of the early 150's had poopy brass synchros that were redesigned later on and you can change them out.
I also hear that the R154 is a cousin or is the same just doesn't have the 4wd output plate on the back and you would have to mod the tailplate if you wanted to use it.
I agree the Mua5 is strong and if your 4l30 is going to the grave, you can source a 5speed fairly cheap but I wouldn't say it is any better than the Ar5.
Probably close in terms of strength because they are both "Japanese" and built tough.
Mua5 and Ar5 - and even the 4l30 - They both use the same gear sets for transfer cases, one is internal (mua5) and the other is removable
just adding the 3 cents here.
BTW Good Job John.
lorenzo816
Has thanked: 74 times
Have thanks: 46 times
Postby Ryan Bechtold » Sat Jan 23, 2016 7:57 pm
Hi, can I swap my automatic trans to a manual trans. I'm buying another 88 trooper monday hoping to swap the trans and extra parts. Both are the same year and 4x4, I have a trooper LS and the one in purchasing is a trooper two with automating locking hubs. Not sure if I should sway my manual locking hubs out.
Ryan Bechtold
Postby Bigislandblake » Mon Feb 15, 2016 3:08 pm
Hi Guys great write up! I just recently got done rebuilding the whole front clip on on the 2001 TROOPER I bought that was smashed up by a previous owner, I have a 2000 donor truck with a blown motor. And the rebuild came out really clean.
My 2001 is a 5 speed conversion with an AR5 trans and removable transfer case. It is not hooked up to the 4x4 switch on the dash and the vacuum solenoid/actuator on the front axle also does not engage. I wanted to know if there was a way I could rig a switch up to the transfer case shift motor to use my 4x4.
Any help would be great. This truck has great gear ratios and plenty of torque with the 3.5.
Aloha from Hawaii
Blake
Bigislandblake
Postby DSUZU » Mon Feb 15, 2016 6:17 pm
Ryan Bechtold wrote:Hi, can I swap my automatic trans to a manual trans. I'm buying another 88 trooper monday hoping to swap the trans and extra parts. Both are the same year and 4x4, I have a trooper LS and the one in purchasing is a trooper two with automating locking hubs. Not sure if I should sway my manual locking hubs out.
Take careful measurements. With an 88, you most likely have the 2.6 and an Aisin automatic (a fairly good automatic tranny). With the later 2.8s, there is a different frame between the autos and manuals. If you have a complete donor, the swap will be much easier. Dennis
Has thanked: 208 times
Have thanks: 577 times
Return to Drivetrain Mods
Users browsing this forum: Bing [Bot] and 3 guests
