indy4x swayaway torsion bars
Re: indy4x swayaway torsion bars
Postby EricJette » Wed Oct 31, 2012 11:41 am
Ok, I'm going to ask what may be a really, really dumb question here, but why would you need to replace the torsion bars in the first place?
95% mech. restored 2dr. /2 seat / '86 Trooper w/ A/C , New 1mil over-bored 2.3L (2305cc)/ All OEM Johnny5ive-built custom "5zd1", w/ 2.6 valves &"Jerry cam" in the 2.3L head/ custom built 3-core radiator/ Exedy clutch & rebuilt msg-5 tranny/ 30/9.5/15's on snowflakes/superwinch manual hubs/fully rebuilt front end - KYB shocks w/ steering dampener & Calmini torsion bars/ 89RS leaf springs w/90mm shackles/custom wood interior paneling & bedlined flooring w /Calmini tri-Y header w/high-flow cat and muffler on 2.25" stainless pipe.
Desert Trooper;
viewtopic.php?f=15&t=61131
Shaolin school of Isuzu graduation day; "And now little trooper, when you can grab this socket wrench from my hand, it will be time to start your engine."
EricJette
Has thanked: 265 times
Have thanks: 277 times
Postby recon » Mon Nov 12, 2012 11:03 pm
i finally installed my sway a way torsion bars yesterday,i bought them in august of 2010 lol 8) recon
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53703&hilit=evolution+of+my+truck
recon
Has thanked: 109 times
Have thanks: 47 times
Postby GoodyMOBB » Tue Nov 13, 2012 12:12 am
Lol you sound as bad as me. I started replacing the suspension last September... So far I'm one upper ball joint down. Good thing it's just a project.
GoodyMOBB
Has thanked: 46 times
Have thanks: 68 times
Postby recon » Wed Nov 14, 2012 1:54 pm
GoodyMOBB wrote:Lol you sound as bad as me. I started replacing the suspension last September... So far I'm one upper ball joint down. Good thing it's just a project.
yeah but i also did an aussie locker installation and a 1.5 inch diff/cross member drop at the same time 8) recon
recon
Postby jwood1016 » Sun Nov 25, 2012 4:29 pm
EricJette wrote:Ok, I'm going to ask what may be a really, really dumb question here, but why would you need to replace the torsion bars in the first place?
This is something I often wonder. To me the main purpose is to compensate for a bumper and a winch. I would think that stiffer bars would lead to less front end flex but I'm not using them so honestly I don't know for sure.
John
2002 Trooper
3 inch lift and 33's
jwood1016
Have thanks: 18 times
Postby EricJette » Sun Nov 25, 2012 8:47 pm
I suppose if you add 200 + lbs to the front end with a bumper, brushbar and winch you'd need to compensate for sag and go with stiffer T-bars if cranking them wouldn't keep the front end from bottoming out in the rough stuff more than it would otherwise.
Thanks, that actually make logical sense. I was thinking more along the lines of age and metal fatigue possibly being the primary reason (given a quarter century of loading and vibration imposed on them).
Desert Trooper;
EricJette
Postby recon » Thu Dec 13, 2012 10:04 am
recon wrote:i finally installed my sway a way torsion bars yesterday,i bought them in august of 2010 lol 8) recon
i forgot to post a pic lol 8) recon
recon
Postby Rodeo Song » Fri Jan 04, 2013 12:50 pm
Coming from a performance autocrossing Porsche 911 background, I went with the stiffer bigger Sway-a-Way T-bars simply for less body-roll while cornering hard at speed. Especially if you're lifting the rig even a minor 1-1.5 with OME Old Man Emu rear springs.
Yes stiffer t-bars will help with winch/bumpers and additional weight, but I did it soley for performance and handling. Plus the 1.5" lift looks beechin good.
- Dave
3rd Rodeo is the charm......
1991 4x4 Rodeo 2.8L 5speed (traded in for the 1997)
1997 4x4 Passport 3.2L 5speed retired (sold)
2004 4x4 Rodeo 3.5L Direct Injection Rocketship
rodeo song link: http://www.youtube.com/watch?v=Qh2VU8mP ... re=related
Rodeo Song
Trail Scout
Postby squatch » Sat Feb 02, 2013 3:45 pm
The stiffer bars actually ride better! Less body roll and Brake dive disappears. All Isuzu's have way too soft front springs for my taste. I've replaced the TB's in all 3 of my Troopers. Add some good shocks and HD sway bars and it's a whole different vehicle on the road. I don't loose flex off road and the tires stay planted.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
squatch
Has thanked: 66 times
Have thanks: 328 times
Postby EricJette » Sat Feb 02, 2013 3:57 pm
Thanks, I'll take this into consideration though my body roll in minimal as is brake dive with the KYB's and a tight front end...T-bars have been tweeked and ride hight is to stock spec.
Desert Trooper;
EricJette
Postby recon » Sat Feb 02, 2013 6:04 pm
for most people heavy duty torsion bars are not necessary.for me they were.my truck rides and handles much better now 8) recon
recon
Postby Psychomidgit » Wed Feb 20, 2013 12:36 pm
What kind of grease did you use on the splines?
88 Isuzu Trooper II LS w/ 2.6L, Undergoing Drive/Powertrain Rebuild
91 Honda CRX Dx w/ B16A JDM Swap, Rear Disc Conversion, JDM Front End, JDM Rear Interior
13 Chevy Cruze LT RS w/ 1.4L Turbo, Trifecta Tuned w/ Forge BOV, All amber lights changed to white, shifter swapped and interior done with green accents, all silver interior pieces repainted in a Mercedes metallic silver.
88 LS Build Thread
viewtopic.php?f=15&t=68173
Look at this before "converting" to HIDs
http://www.danielsternlighting.com/tech ... d/HID.html
Psychomidgit
Trail Scout
Has thanked: 15 times
Have thanks: 6 times
Postby ZuminaZX » Sat Nov 30, 2013 5:00 pm
where do you order the sway-aways from?
2004 Rodeo 3.5 DI
ZuminaZX
Have thanks: 22 times
Postby Rodeo Song » Fri Feb 27, 2015 5:29 pm
Major thanks to Independent 4x4 / my Sway-a-way T-bars per my above post.
I'd had them on my rig about 4-5 years (check my previous photo post date)
Independent 4x stepped up to the plate and replaced a t-bar that I somehow managed to crack in half, and I don't do off-roading my my 2004 3.5 DI rodeo.
Looked like a casting flaw in the iron due to a rusty pattern internal to the forged t-bar that propagated from a crack. after a couple of short phone calls and me sending them pictures, they warrantied and even sent me 2 new t-bar units free of charge including shipping.
THAT is good customer service. Thank you Indy 4x
- Dave
Rodeo Song
Trail Scout
Postby Heffalump » Tue Mar 24, 2015 1:19 pm
Wife is tired of the Heffalump's nose rolling and diving. Since the upcoming project list includes bumpers and a winch, I just ordered a set of bars from Indy4X. Very excited!
1990 Trooper
4ZE1 .020" over / 95 Rodeo cam
MUA-5 w/ 3.07:1 Revo Gearset
Round eyes up front, G80 in the rear
31x10.5 BFG TA/KO - 15"x8" 3.75
Heffalump's Pics
Heffalump
Have thanks: 9 times
Postby mudoilngears » Tue Mar 24, 2015 1:30 pm
You won't be sorry!
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, more mods to come!
Build in progress...
mudoilngears
Has thanked: 12 times
Have thanks: 64 times
Postby miked1023 » Tue Jun 30, 2015 3:25 am
hello there!
there was a half inch difference in height between the left and right side of my truck (TFR 54)....adjusted the left side torsion bar (about 2 turns) and now it is level.
but there is a 10 mm difference on the protruding length between the (left & right) adjuster bolts. do i need to reindex the torsion bars? or should i let it be that way? take note that the truck is now level.
i bought this truck used and probably repairs were done on the suspension and the torsion bars were not indexed properly.
miked1023
Postby mudoilngears » Tue Jun 30, 2015 10:16 am
Best to start a new topic for this kind of question. I wouldn't reindex for a 10mm difference, so long as the adjuster isn't maxed out it shouldn't be a problem.
mudoilngears
Postby Rodeo Song » Wed Jul 01, 2015 12:44 pm
mudoilngears wrote: I wouldn't reindex for a 10mm difference, so long as the adjuster isn't maxed out it shouldn't be a problem.
Yup, just don't bottom out the big adjustment bolt, but if you need to re-index (I've had to before, after the initial guess-mate install positioning) It's fast if you choose to re-index the front splines. To fix your mis-matched positioning, just mark a line across the T-bar and receiving frame mount with a sharpy pen, then just reclock from this index point up/down 2-3 splines. Very quick and easy to do once you have the t-bar installed and in-place.
- Dave
Rodeo Song
Trail Scout
Postby totten » Mon Jul 04, 2016 7:27 pm
Thanks for info.Good write up.
totten
Have thanks: 83 times
Postby Rodeo Song » Tue Jul 05, 2016 7:04 pm
totten wrote:Thanks for info.Good write up.
Buy me a beer? Send it to PO Box 1369............
- Dave
Rodeo Song
Trail Scout
Previous
Return to Drivetrain Mods
