installing trooper springs into 2nd gen rodeo writeup
Re: installing trooper springs into 2nd gen rodeo writeup
Postby Fairchild » Mon Jan 16, 2012 3:30 pm
Just a quick note. Should have mentioned, this is for a 99 Isuzu Rodeo 2 wheel drive 6cylinder 3.2.
Was considering this for a 2" lift before I broke a spring. Or is their a better more ideal way of doing this? All suggestions are greatly appreciated.
Fairchild
Postby holger » Mon Jan 16, 2012 3:52 pm
Fairchild wrote:Just a quick note. Should have mentioned, this is for a 99 Isuzu Rodeo 2 wheel drive 6cylinder 3.2.
OME912 will give you 1.5" or 2" lift for your Rodeo.
OME913 would give you around 0.5" - 1" lift.
This is comparing to a vehicle with the new stock coils. If you compare it to a vehicle with some old sagged stock coils, you will see higher lift.
Oleg
Axiom 4WD 2004
ARB front locker; No-Slip rear; bent rear flexible links; TC coils, 2" spacers; extra long shocks; adjustable track bar; IronMan torsion bars; etc
For this post the author holger was thanked by:
sidgarza
holger
Has thanked: 32 times
Have thanks: 44 times
Postby Fairchild » Mon Jan 16, 2012 5:08 pm
This is the magical answer to my question - You are Da Man much appreciated sir!
Fairchild
Postby clipper 03 rodeo » Tue Jan 17, 2012 4:18 pm
Actually OME 913's will give you a 2" lift, and OME 912's will give you a 3" lift. I have put 913's on my Rodeo that only had 50k miles and wasn't sagging at all, and got a full 2" of lift. Others have measured their 912's and got right at 3" of lift.
NEW - 2016 GMC Sierra All Terrain
NEW- 2017 Jeep Renegade Latitude 4x4
TRADED IN -2004 Clipper Blue Isuzu Rodeo - 3.5L DI - Aisin Auto Tranny - 3" Lift, Calmini Upper Links, Skyjacker Shocks (extended rears), 32" Procomp AT Tires, OEM 15" Snowflakes, Headlight Projector Retrofit, Bull Bar, ect..
TOTALED =( -2003 Clipper Blue Isuzu Rodeo
clipper 03 rodeo
Has thanked: 21 times
Have thanks: 71 times
Postby holger » Wed Jan 18, 2012 4:17 pm
clipper 03 rodeo wrote:Actually OME 913's will give you a 2" lift, and OME 912's will give you a 3" lift. I have put 913's on my Rodeo that only had 50k miles and wasn't sagging at all, and got a full 2" of lift. Others have measured their 912's and got right at 3" of lift.
This is not what I observed on my 2002 Rodeo. On the new Rodeo, 913s gave me almost no lift. 912s, together with 2" spacers, gave me 4" of lift (4-2=2).
The same figures I got on the Axiom, so this is a consistent situation. Now I am using 929s (much stiffer and larger coils than 912s), and those are giving me just 3" of lift without spacers. No way 912s can give the same amount of lift as 929s.
Oleg
Axiom 4WD 2004
holger
Postby Fairchild » Wed Jan 18, 2012 4:37 pm
I'm curious if their would be a difference between 2wheel and 4wheel drives. I know the chassis are the same but the weight distribution and shock ( aftermarket or stock ) make a difference maybe?
Haven't decided on exactly what to buy yet. Still considering some used shocks. absolute height is not critical. I was hoping to get at least 2" but no more than 4". I'd be happy with under 3" just so I dont have to change the shocks and extend the brake line to be honest.
Fairchild
Postby clipper 03 rodeo » Wed Jan 18, 2012 4:51 pm
That's strange Holger. I'm not saying your wrong or anything, but many people here have gotten a 2" lift with 913's (like myself) and a 3" lift with 912's. Gizmo has put 912's on 3 different Rodeos and got a 3" lift out of all of them.
clipper 03 rodeo
Postby clipper 03 rodeo » Wed Jan 18, 2012 4:58 pm
Fairchild wrote:I'm curious if their would be a difference between 2wheel and 4wheel drives. I know the chassis are the same but the weight distribution and shock ( aftermarket or stock ) make a difference maybe?
I don't think it really makes a difference with how much coils will lift the rear rather its 4x2 or 4x4. Yeah if you're not wanting to deal with the shocks and such right now just get the 913's for the 2" lift. Like me you can just add spacers later on if you want some more lift.
clipper 03 rodeo
Postby holger » Wed Jan 18, 2012 5:05 pm
clipper 03 rodeo wrote:That's strange Holger. I'm not saying your wrong or anything, but many people here have gotten a 2" lift with 913's (like myself) and a 3" lift with 912's. Gizmo has put 912's on 3 different Rodeos and got a 3" lift out of all of them.
I do not know what to say. Did you take into account the new larger tires ? Did you measure the lift immediately after the lifting, or did you give it time to settle (a month may be) ?
After few months the OME settle back at least 1". All OMEs that I personally tried on 2 vehicles (913, 912, 919, 929) did just that. So, to get a permanent lift of 1.5" - 2" you need the initial lift of 3". This is 912s.
OME lists in their catalog that 913s provide just .75" of lift for the Rodeo. You can check it on their site. And this is consistent with my results on 2 different vehicles. To say that OME is so way off about their own products... provided I double-checked it myself, independently... it would be a bit of stretch.
Oleg
Axiom 4WD 2004
holger
Postby clipper 03 rodeo » Wed Jan 18, 2012 5:18 pm
Actually I installed the 913 coils with the stock rims/tires the measured and it was right at 2". Then I installed 30" tires after that and it gave me about another 1/2". I also measured them about a month later (since I waited a bit to get an alignment, and I wanted to make sure the t-bars were cranked about an inch under the height of the rear to give it some rake) and they settled maybe 1/8th of inch. I also re-measured about 3 months after that before installing my spacers and 32" tires and they were still at the exact same height.
I completely see where your coming from, but the fact is multiple (not just a couple) people have gotten the same results of 2" with 913's and 3" with 912's. Not much else can be said about it.
Last edited by clipper 03 rodeo on Wed Jan 18, 2012 5:21 pm, edited 1 time in total.
clipper 03 rodeo
Postby holger » Wed Jan 18, 2012 5:18 pm
It does not matter, they will work the same way.
Fairchild wrote:Haven't decided on exactly what to buy yet. Still considering some used shocks. absolute height is not critical. I was hoping to get at least 2" but no more than 4". I'd be happy with under 3" just so I dont have to change the shocks and extend the brake line to be honest.
If money is not an issue, and you do not need really long shocks for off-road, then take OME shocks application for Rodeo. They are a little bit longer than "stock height" shocks (OME shocks extend more than other shocks with the same length) and they are good through the whole suspension travel on a lightly lifted vehicle.
If money is the issue, then just take some Monroe or KYB, both are cheap.
Used shocks are not a good idea.
Oleg
Axiom 4WD 2004
holger
Postby holger » Wed Jan 18, 2012 5:19 pm
clipper 03 rodeo wrote:Actually I installed the 913 coils with the stock rims/tires the measured and it was right at 2". Then I installed 30" tires after that and it gave me about another 1/2".
did you check the height after a month or two ?
Oleg
Axiom 4WD 2004
holger
Postby clipper 03 rodeo » Wed Jan 18, 2012 5:22 pm
Edited my post above with the answer to this question.
clipper 03 rodeo
Postby holger » Wed Jan 18, 2012 5:27 pm
clipper 03 rodeo wrote:I also measured them about a month later (since I waited a bit to get an alignment, and I wanted to make sure the t-bars were cranked about an inch under the height of the rear to give it some rake) and they settled maybe 1/8th of inch. I also re-measured about 3 months after that before installing my spacers and 32" tires and they were still at the exact same height.
This is strange and not typical. Many people complained here about too much settle in OME. And I observed this set back myself. But... "your results may vary".
Oleg
Axiom 4WD 2004
holger
Postby holger » Wed Jan 18, 2012 5:41 pm
clipper 03 rodeo wrote:I have put 913's on my Rodeo that only had 50k miles and wasn't sagging at all, and got a full 2" of lift.
By the way, 50K miles is still a mileage. And there were several years of permanent pressure on the coils by the vehicle weight. You cannot say that "it wasn't sagging at all". You just did not see that it was sagging - a little, an 1", for example.
I observed how my former OME 919s sagged (initially) 1" after 1 (just one) trip of about 1000 miles (including some 'wheeling). Before the trip, I could not fit my vehicle in the garage; after the trip, it was fitting perfectly with some extra clearance.
The 913s and the stock coils are much smaller than 919s.
Oleg
Axiom 4WD 2004
holger
Postby clipper 03 rodeo » Wed Jan 18, 2012 6:08 pm
I do agree that all springs sag. All i'm saying is that if I could get a full 2" with lift with 913's after measuring against some VERY good condition low mileage stock springs, there isn't any reason someone with high mileage beat-on springs shouldnt get 2" of lift with the 913's.
Last edited by clipper 03 rodeo on Wed Jan 18, 2012 6:15 pm, edited 2 times in total.
clipper 03 rodeo
Postby holger » Wed Jan 18, 2012 6:11 pm
clipper 03 rodeo wrote: there isn't any reason someone with high mileage beat-on springs shouldnt get 2" of lift with the 913's.
that's true.
I am used to relatively low-mileage vehicles. My Rodeo was totaled when it was just 60+K miles. My current Axiom has only 40K miles. I use them extensively, and I put lots of mods in them, but I drive them only for recreation (camping trips and the trail riding). This is why they may see lots of new coils/shocks/etc in their lives but not many miles. I am always comparing to the "new" vehicle height.
Oleg
Axiom 4WD 2004
holger
Postby Crash » Thu Feb 09, 2012 3:09 pm
great write up and job on the truck!
Yah I got some stuff under the hood
Crash
Have thanks: 13 times
Postby gabriel3hc » Sun Mar 25, 2012 7:40 pm
Good info. Thanks!!
--White 99 Passport-- 3" Inde4x Lift, Black 15x7 Steels w/31x10.5x15 BFG A/T, Yakima Roof Rack, 00'-02 Headlight assembly and grille, Reverse Glow Gauges, New Sony deck, Alpine component 6.5", 500wt Alpine amp & 12" Kenwood sub.
*Future additions*: Winch bumper, Custom frame sliders, Custom rear bumper with swinging rear tire mount, Locking hubs, 5% tint
gabriel3hc
Postby ravi261 » Wed Mar 28, 2012 12:10 am
Finally got around to doing this today. Good write up too. I too spent about 30 minutes messing with the upper link bolt trying to get both side in, but then I gave up and went inside to get a drink. As I was surveying the situation while having said drink, I had an epiphany. This is what I came up with:
C-Clamp baby!
If you can get the upper link close enough in the bracket, just slap on the c-clamp and tighten, it should line up pretty well. I had one side in already, so it lined up smooth like butter. If you choose to do this, make sure you use the curved part of the clamp on the back of the bracket to hold the upper link in place, otherwise it will keep slipping out when you tighten the clamp.
Sort of like this:
notice how the upper link is being held by the curved part and not the actual clamp part. I hope this saves someone the trouble I went through (if you look in the pic you can see all the scratches I put in/around the bracket).
On a side note: oddly the driver's side only added a 1&1/4" where the passenger's side went up 2". I checked the front and both sat level, so I'm sort of wondering what's up with that?
1999 3.2 V6 4wd Rodeo LS 178k 4L30-E
For the 1st time since 2006, everything works! (including ABS :) )
For this post the author ravi261 was thanked by:
steve600cc
ravi261
Has thanked: 2 times
Have thanks: 67 times
Postby Fairchild » Mon Apr 02, 2012 8:20 am
What year Trooper springs will work for this? My Assumption was 98-2005 but no one ever clearly stated this fact. I tried to use my auto zone app in the salvage yard Saturday and remembered they don't sell our suspension so I couldn't verify if they were the same part #. Waiting on a possible deal with BlackBeauty's lift and didn't want to spend cash on a new lift If I'm buying his. Also wife needs a 2" lift to fit her new tires and bf was looking for a cheap 2" lift to gain necessary clearance.
Fairchild
Postby clipper 03 rodeo » Mon Apr 02, 2012 4:03 pm
98-02 Trooper springs will work, the Trooper was discontinued in 2002.
clipper 03 rodeo
Postby Fairchild » Mon Apr 02, 2012 4:28 pm
Meh they newest they had was a 97 looked really similar inside but wasn't sure. Guess it's back to the hunt.
Fairchild
Postby ZuBrew » Thu Apr 05, 2012 4:46 pm
'97 will work. Any Trooper with coil springs in the rear.
1999 Honda Passport
2WD / OME 913s / 31X10.5X15 / Gabriel Ultras - SOLD
1996 Acura SLX
G80 / OME 919s / 31X10.5X15 BFG / Aisin Hubs
1994 FZJ80
CDL w/7Pin Mod / OME Med / 285/75/16 AT
ZuBrew
Have thanks: 23 times
Postby Fairchild » Fri Apr 06, 2012 8:44 am
I was a little concerned as the 95 Trooper that I was looking at had Coil Springs in the rear and they didn't appear to be the same size. This could be due to age and wear , but wanted to confirm before snagging them.
Fairchild
Return to Drivetrain Mods
cron
