Looking for front left differential input bearing for 1999
Postby adamisaiah5 » Tue May 16, 2017 12:52 am
Looking for any insight/advice! I'm currently at a stand still with my 1999 Trooper and don't know where to look for the correct part. Excuse me if I don't know what I'm talking about because I'm still learning and my buddy is the more knowledagble one. After we removed the entire front left CV axle the bearing from the CV axle shaft going into the differential was completely split in two. Does anyone know where I might be able to find one or what bearing it is I need? I also am looking for two snap rings and the oil seal. Any input would be greatly appreciated. Needing my daily driver back asap. Thanks for reading and hope to hear back
Adam
1999 Trooper 4x4 TOD
adamisaiah5
Re: Looking for front left differential input bearing for 19
Postby geoffinbc » Tue May 16, 2017 9:41 am
Can you read the number on the bearing and seal? Thats the best way to get it if there is not a listing. You can check with Jerry (private message jlemond) or try looking it up on rockauto.com
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Return to Drivetrain Mods
