how do you set ignition timing 2.6 engine
Postby 1995pickup » Mon May 15, 2017 10:31 am
how do you set ignition timing 2.6 engine where do you set the timing at.
what degree for timing .
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Recent 2.6 rebuild with a "Jerry Cam"all parts for engine rebuild came from Jerry Lemond. Bored .40 thounsands and Engine rebuid performed by Johnny 5 .
Latest modification i sa 2.6 all parts from Jerry Lemond including a "Jerry Cam" 40 bored over
pistons. Engine built by the legendary Johnny 5
1995pickup
Has thanked: 22 times
Re: how do you set ignition timing 2.6 engine
Postby itsmehb » Mon May 15, 2017 7:44 pm
1995pickup wrote:how do you set ignition timing 2.6 engine where do you set the timing at.
This is Squatch's hall of fame article on timing the 2.6. Read through it in it's entirety. It's spot on.
viewtopic.php?f=17&t=60015
1991 Pick up (long gone)
2000 Amigo, 2.2 5 speed(sold)
itsmehb
Has thanked: 114 times
Have thanks: 200 times
Postby RickP » Tue May 16, 2017 10:28 am
That thread mostly discusses cam timing. According to Jerry, you don't disconnect anything. You just connect your timing light to the #4 spark plug lead and set timing at 6 BTDC at 800 rpm. However, you need to make sure your timing mark on the damper didn't slip. I personally, rarely use a timing light. I advance the distributor a little bit and take it for a test drive up a long steep hill I have nearby. I keep advancing until I get pinging or and then back it off a hair.
For this post the author RickP was thanked by:
1995pickup
RickP
Has thanked: 34 times
Have thanks: 42 times
Postby 1995pickup » Tue May 16, 2017 1:28 pm
RickP wrote:That thread mostly discusses cam timing. According to Jerry, you don't disconnect anything. You just connect your timing light to the #4 spark plug lead and set timing at 6 BTDC at 800 rpm. However, you need to make sure your timing mark on the damper didn't slip. I personally, rarely use a timing light. I advance the distributor a little bit and take it for a test drive up a long steep hill I have nearby. I keep advancing until I get pinging or and then back it off a hair.
:D Thanks.So I just connect timing light to # 4 plug wire.I was trying to set the timing connected to # 1 plug wire.
1995pickup
Postby RickP » Tue May 16, 2017 2:04 pm
Yes, #1 and #4 are a TDC at the same time, but the TDC mark on the balancer is for #4 compression stroke.
1995pickup
RickP
Postby 1995pickup » Tue May 16, 2017 2:19 pm
RickP wrote:Yes, #1 and #4 are a TDC at the same time, but the TDC mark on the balancer is for #4 compression stroke.
:D Thanks Rick
1995pickup
Return to Drivetrain Mods
