Looking for shock reccomendations
Postby Kylegood » Tue May 09, 2017 10:22 am
Hey gang, I have a 1990 trooper with 3" calmini lift, front and rear. A arms, not just torsion bars.
I'm in need of new shocks front and rear and and looking for reccomendations with part numbers. Obviously I'd like to spend as little as possible. And would prefer to buy in a set. Its a daily driver that sees mild/moderate trail use and off-roading.
I'm sorry if this has been talked to death
So let's here it!
Kylegood
Re: Looking for shock reccomendations
Postby SuperTroop95 » Tue May 09, 2017 10:46 am
Bilsteins are nice, well built, and last a while. Another one I've heard good things about is Rancho something-or-another 9000XL. Word of advice, stay away from twin tubed shocks if you off-road!
1995 Trooper LS
Want to do:
96/97 cam swap
Rebuild heads
Injector Swap
new exhaust
New suspension everything
SuperTroop95
Mi Amigo
Postby mdc0135 » Sat May 13, 2017 1:01 am
check out KYB shocks they fairly. affordable they got 3 different styles. from oem to. big and. beefy, look them up on Rock auto .com good luck
mdc0135
Postby geoffinbc » Sat May 13, 2017 3:27 pm
OME has very nice ones too. If they fit your budget I would get them.
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Postby Grumpfrompahrump » Sat May 13, 2017 9:11 pm
X2 on KYB
Steve
2000 Amigo Ironman, 3.2L Auto 4WD
1982 Cadillac Fleetwood Hearse
1927 Ford Model T Roadster w/327 Chevy
Grumpfrompahrump
Have thanks: 35 times
Return to Drivetrain Mods
