I want to know if a swap is possible
Postby kimble01 » Thu May 04, 2017 8:20 pm
Wikipedia lists several vehicles this transmission comes in. The most popular one (meaning plentiful) is the 1999 BMW 528i. Why couldn't one of those low-mile 4l30e's be used for a replacement? What are the issues? Anybody tried it? I searched for 4l30 and BMW in this forum...
Thanks in advance, and thanks Buster for answering on my other question. Same truck, but the pan turned out to have large chunks in it...so back to the drawing board.
kimble01
Re: I want to know if a swap is possible
Postby DSUZU » Thu May 04, 2017 10:02 pm
Question is, what do you want to swap it into? The majority are 4x4s. We learned from Jerry that the output shafts are different between the 4x4 and the 2wd automatics (there is a removable extension case on the 2wd and it has the same pattern as the transfer case). Beyond that, the output shaft on the BMW tranny may be altogether different. More than likely (but I'm not positive) the bell housing pattern will be different. Dennis
Has thanked: 216 times
Have thanks: 619 times
Postby nasty610 » Fri May 05, 2017 7:16 am
The bellhousing pattern is completely different on pretty much all the applications. As far as I know Isuzu is the only company that used the optional lower ratio gearset. All the cars used the standard taller gearset and I can tell you first hand it sucks. I have a 95 525i with a 4l30 and it's unblieveby slow off the line. My 91 Trooper v6 is actually faster until my 525 can hit 2nd and 4000rpms. The only plus side to the BMW version is the deeper oil pan.
1996 Isuzu Trooper Base model
1991 Trooper Base Model
Lift Coil Spring Options
nasty610
Has thanked: 21 times
Have thanks: 208 times
Postby kimble01 » Fri May 05, 2017 7:44 am
DSUZU wrote:Question is, what do you want to swap it into? The majority are 4x4s. We learned from Jerry that the output shafts are different between the 4x4 and the 2wd automatics (there is a removable extension case on the 2wd and it has the same pattern as the transfer case). Beyond that, the output shaft on the BMW tranny may be altogether different. More than likely (but I'm not positive) the bell housing pattern will be different. Dennis
No Dennis you misunderstand me. I want to use one of those transmissions in my truck. I have 2 bad transmissions that i could scavenge parts from, like the bellhousing, to make it work. I looked at pictures of the BMW transmission and can tell the electrical connectors are completely different, looks like the bimmer uses a single connection. Taller gear ratio might not be all that bad, not wanting to race it anyway...and I can get one of these from car-part from $60! The cheapest one that is from a rodeo is $450 from the same source!
kimble01
Postby nasty610 » Fri May 05, 2017 10:50 am
It's not about racing. The fact is the taller ratios make getting the vehicle moving a real pain and requires a lot of throttle. My 525 weights about the same as my 91 Trooper but has another 70 hp. Around town the car is a complete dog and won't accelerate with traffic unless I really get in the throttle. My Trooper on the other hand is quite manageable and I rarely need more then 1/2 throttle to keep up. If I had the taller gears in the Trooper I'd be at full throttle just trying to leave a stop light with traffic. Unless you plan on adding a lot of power I'd suggest staying with an isuzu spec'd 4l30.
nasty610
Postby kimble01 » Fri May 05, 2017 12:38 pm
nasty610 wrote:It's not about racing. The fact is the taller ratios make getting the vehicle moving a real pain and requires a lot of throttle. My 525 weights about the same as my 91 Trooper but has another 70 hp. Around town the car is a complete dog and won't accelerate with traffic unless I really get in the throttle. My Trooper on the other hand is quite manageable and I rarely need more then 1/2 throttle to keep up. If I had the taller gears in the Trooper I'd be at full throttle just trying to leave a stop light with traffic. Unless you plan on adding a lot of power I'd suggest staying with an isuzu spec'd 4l30.
Ah ok, I'm listening...damn.
kimble01
Return to Drivetrain Mods
