2001 Condensor fan upgrade for 1998-2000
Postby Tg16 » Mon May 01, 2017 3:17 am
Has anyone added the Factory 2001 condenser fan to a 2000 or older trooper?
I have added dual aftermarket ones to my SLX but was wondering if anyone added the factory one or knew how to wire it to factory harness.
Adding the Dual fans to my SLX has made the AC work like never before.
on the 2000 wanted to keep it more stock so was inquiring.
1998 SLX
2000 Trooper
2002 Rodeo
Tg16
Re: 2001 Condensor fan upgrade for 1998-2000
Postby geoffinbc » Mon May 01, 2017 9:52 am
Most likely it is a simple relay wired to the clutch coil.
Personally I am a big fan of the Flex A Lite soft start controller. It ramps up the fans slowly to avoid the big startup spike the fan motor causes
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Return to Drivetrain Mods
