Calmini 3" suspension lift. Looking for instructions
Postby Kylegood » Sat Apr 29, 2017 2:57 pm
After numerous attempts at contacting calmini with no luck I am turn to you guys on the forum. I am looking for the installation instructions scanned, photocopied, PDF. I don't care what format. I am looking for the manual for the 3" suspension lift for 1st gen troopers.
Hopefully someone can help.
Apologies if this isn't posted in the right forum.
Thanks
Kylegood
Re: Calmini 3" suspension lift. Looking for instructions
Postby geoffinbc » Mon May 01, 2017 9:56 am
Most people here have had the same vad experience with Calmini. Have you only emailed or have you called?
If no one comes through with instructions just ask here and we can guide you through it. All kits or systems work the same on these trucks.
Have thanks: 323 times
Postby Kylegood » Mon May 01, 2017 10:15 am
I have emailed multiple times, and called twice with no answer.
Basically I have a parts truck with the lift in it, that I want to transfer another truck. And want to ensure that when transferring it all that I do correctly in the right order to prevent any problems with fitment and other complications
Kylegood
Postby Dingbat » Mon May 01, 2017 11:39 am
I have an instruction sheet for the 1st gen Rodeo model, I can try to summarize the order, etc. when I dig it out in the next few days.
1997 UCS7VF (Rodeo / Passport / Frontera)
Wry Wench build thread
3-inch Calmini Lift Kit, Indy4x 1.5-inch Leaf Lift
Dingbat
Have thanks: 61 times
Postby geoffinbc » Wed May 03, 2017 4:09 am
Wow it sounds like they are barely in business these days. You can't miss that many correspondents and maintain a minimal customer base.
Postby egagnon086 » Wed May 03, 2017 6:47 am
I'd say that all of it will just unbolt and then you can install in the reverse order. It's not a delicate operation.
egagnon086
Has thanked: 53 times
Have thanks: 92 times
Postby gb89amigo » Wed May 03, 2017 9:14 am
Kylegood,
As mentioned above, not that difficult! You will find that taking multiple careful pictures may enormously aid in reassembly on your latest ride. Make the pictures large enough so it will be clear how it goes back together. Take an overview, then sub-assemblies to ensure accurate assembly. Take more shots than you think you'll need, just for insurance! HOH!
Cheers,
GB
'89 Amigo XS RWD, 4ZE1, MUA5, HC6 (Rear Wheel Drive, 2.6L Fuel Injected, 5 spd trans f/ 2.6L and up, 4.56:1 differential 2WD/4WD)
Future: Install the "Big Brake" upgrade, so I don't break things! . Acquired '95 V6 Passport/Rodeo front rotors (11.04") and assemblies. Need to pull G80/LSD rear from '92-'97 Trooper.
'90 Amigo 4WD, Parts car
More FUN!!! :)
gb89amigo
Has thanked: 49 times
Have thanks: 116 times
Return to Drivetrain Mods
Users browsing this forum: Bing [Bot] and 2 guests
