Questions for those with pace setter header
Postby dryvr12 » Mon Apr 24, 2017 12:24 pm
For those with a pace setter header on the 4ze1, are oxygen sensor and EGR bungs already welded on?
I am considering removing the EGR pipe and capping the vacuum lines going to the valve. Will I notice and adverse effects by removing the EGR? The slight difference in AF ratio will be corrected by the O2 sensor correct?
Zack
1988 Trooper LS 2.6L Auto to manual swap, Asin hubs, 228k+
http://forum.planetisuzoo.com/viewtopic.php?f=15&t=50707
LED gauges, sony h/u, alpine speakers, jl audio w3's, grant steering wheel, cup holders, procomp 98s
Odometer correction: http://forum.planetisuzoo.com/viewtopic.php?f=1&t=67546
Dome light fix: http://forum.planetisuzoo.com/viewtopic.php?f=17&t=62898
LEDs:http://forum.planetisuzoo.com/viewtopic.php?f=1&t=51643
dryvr12
Have thanks: 43 times
Re: Questions for those with pace setter header
Postby oldestisuzuist » Mon Apr 24, 2017 1:04 pm
"For those with a pace setter header on the 4ze1, are oxygen sensor and EGR bungs already welded on?"
Yes.
EGR is M22x1.5, O2 sensor is M18x1.5 in case you want to plug either.
'78 LUV, 1.9, headers, 4-spd, SAS Dana 30 front, Dana 20, SOA rear w/Aussie Locker, 31's, serious body cancer, bought new 12/4/78.
'87 Trooper, 2.3, headers, 5-spd, 31's, ball joint flip, Aussie Locker rear, Superwinch hubs, brush guard w/5.5K winch, needs motor, work in progress.
oldestisuzuist
Have thanks: 247 times
Postby DSUZU » Mon Apr 24, 2017 5:10 pm
My EGR tube broke about a year ago. I welded up the exhaust end (plugged) and screwed it back in. Unplugged the vacuum hoses to keep the intake end sealed (too lazy to install the replacement pipe I already had). FWIW, I feel my MPG DROPPED by about 1 MPG. Dennis
Has thanked: 216 times
Have thanks: 615 times
Postby dryvr12 » Tue Apr 25, 2017 12:40 pm
Just what I was looking for, thanks!
Zack
dryvr12
Return to Drivetrain Mods
Users browsing this forum: Google Adsense [Bot] and 3 guests
