HELP!!! BJ flip/ BJ spacer?? 92 rodeo
Postby eduu_PR » Thu Apr 20, 2017 12:04 pm
FIRST POST! :wink:
I have been doing allot of reading on torsion bar lift but still need some more details plz.
I understand that fliping the BJ and adding a spacer is only needed when lifted to acheive alignment and keeping up and down travel centered on the upper arm. I have been looking online but all i find is a 1/4" spacer for my rodeo, witch seems like nothing compared to 1"-1.5" spacers found for other type of veicles like Toyotas for example. ANY SPECIFIC REASON? other than alignment issues?? because i could just have a buddy of mine with a 3d printer make me some 1/2",3/4" or 1" spacers instead. :idea:
I know i cant go further than 3" torsion lift on stock parts, but i want to try to keep my upper arm travel as centered as posible after lift. witch i figured would be the other reason to Bj flip and space. RIGHT??
please correct if anything i wrote is incorrect. :mrgreen:
should i just get the 1/4" spacers or have some built bigger??
anyone know how thick the built in spacer on the calmini top arm is on the 3" lift kit???
im riding on 31" Cooper Discoverer with a 1" wheel spacer and hate when she rubs :cry:
eduu_PR
Re: HELP!!! BJ flip/ BJ spacer?? 92 rodeo
Postby DSUZU » Thu Apr 20, 2017 5:48 pm
Reality: 31s were a factory option - with stock suspension adjustment. The BJ spacer isn't all that necessary with 31s. For best CV life with a lift, you need to do the front diff drop (do a search on it). You'll need modified brackets (believe someone here offers them). Dennis
For this post the author DSUZU was thanked by:
eduu_PR
Has thanked: 216 times
Have thanks: 619 times
Postby geoffinbc » Thu Apr 20, 2017 7:17 pm
On our trucks the spacers are simply to correct UCA angle and make alignment possible. They are not needed on a mild lift. Larger spacers would introduce alignment issues in the oposite direction.
Toyota trucks had the torsion bar on the UCA so a spacer here would actually provide lift.
For this post the author geoffinbc was thanked by:
eduu_PR
Have thanks: 323 times
Postby eduu_PR » Fri Apr 21, 2017 2:17 am
geoffinbc wrote:On our trucks the spacers are simply to correct UCA angle and make alignment possible. They are not needed on a mild lift. Larger spacers would introduce alignment issues in the oposite direction.
makes sense, thnks!
eduu_PR
Postby eduu_PR » Fri Apr 21, 2017 2:19 am
DSUZU wrote:Reality: 31s were a factory option - with stock suspension adjustment. The BJ spacer isn't all that necessary with 31s. For best CV life with a lift, you need to do the front diff drop (do a search on it). You'll need modified brackets (believe someone here offers them). Dennis
inhad previewsly cranked up like 1" for the new shoes bit need a bit more space when weeling, when slightly turned to the right my passnger tire will rub . thats why im going a bit taller
ok so, crank T bar, lower front Diff, then if allignment isnt posible flip upper BJ.
Thats the order i should go with? right?
eduu_PR
Postby geoffinbc » Fri Apr 21, 2017 4:26 am
If your going to have a total of roughly 2" then go ahead and do the flip but no spacer.
Postby DSUZU » Fri Apr 21, 2017 8:43 am
geoffinbc wrote:If your going to have a total of roughly 2" then go ahead and do the flip but no spacer.
Agreed. Plenty of write up on doing this. Dennis
eduu_PR
Postby eduu_PR » Fri Apr 21, 2017 2:39 pm
flip done (no spacer)
will post pics of final product soon
THANKS GUYS
eduu_PR
Postby eduu_PR » Fri Apr 21, 2017 5:46 pm
back side
eduu_PR
Postby eduu_PR » Fri Apr 21, 2017 5:52 pm
done! will go to allignment tomorow morning
eduu_PR
Postby eduu_PR » Fri Apr 21, 2017 5:55 pm
front side!!
THANKS AGAIN GUYS!!
eduu_PR
Return to Drivetrain Mods
