4JG2 Diesel conversion on 2001 Trooper LS
Postby rmfurr » Tue Mar 14, 2017 1:27 pm
I have a friend that is doing a diesel conversion for me with a JDM 4GJ2 engine on an old 2001 trooper LS I bought just for this purpose. Does anyone on the forum have experience with this process and ideally this specific vehicle that I could ask some questions.
It seems like we've run into some problems. My friend said the motor mounts are too inches too far back and need to be moved. He also said that my Trooper has a limited slip differential and that the drivechain is not connecting properly to the new engine and he will have to go get a regular differential from another trooper in the junkyard to make it work.
Anyone familiar with these issues?
rmfurr
Re: 4JG2 Diesel conversion on 2001 Trooper LS
Postby Dingbat » Tue Mar 14, 2017 6:05 pm
do a search on your favorite search engine for iPupGary and Super Trooper ...
Wry Wench build thread
Dingbat
Has thanked: 15 times
Have thanks: 61 times
Postby Ricky » Tue Mar 14, 2017 8:51 pm
That build thread is impressive!! Total frame up rebuild.
Ricky
Drives in Mud
Postby rmfurr » Sun Apr 16, 2017 12:07 pm
Very awesome thread! Is there anyone else on these forums that has experience with a diesel swap into a 2001 trooper? I'd like to find someone that I can ask a few questions.
2001 Isuzu Trooper LS - 4WD - 4JG2 Diesel Conversion
rmfurr
Postby bellavesus » Sun Apr 23, 2017 8:55 pm
As I understand it, if you are swapping from a 4 cylinder gas motor to a 4 cylinder diesel then mounts should line up. Your rear diff should not interfere with the engine swap in any way- although your driveshaft may need to be modified due to engine or transmission difference. IE, the automatic and manual transmissions are different lengths. Easiest swap is a 4 cyl man to 4 cyl manual. Good luck!
Reason is poor propaganda when opposed by the yammering, unceasing lies of shrewd and evil and self-serving men. ~Heinlein
86' isuzu trooper, now with 4JB1TC! OME/INDY 3"
Custom WVO system, Dual tanks.
89' trooper c223t swap-SOLD
bellavesus
Have thanks: 8 times
Postby mudoilngears » Mon Apr 24, 2017 9:26 am
rmfurr wrote:Very awesome thread! Is there anyone else on these forums that has experience with a diesel swap into a 2001 trooper? I'd like to find someone that I can ask a few questions.
If they're Trooper specific questions, I can't help, but I swapped a 98 Rodeo, glad to answer anything I can.
1998 Rodeo LS 4x4 4JB1-TC Diesel Swap, more mods to come!
Build in progress...
mudoilngears
Has thanked: 12 times
Have thanks: 64 times
Return to Drivetrain Mods
