DOHC to SOHC Intake
Re: DOHC to SOHC Intake
Postby Johnny V » Wed Mar 29, 2017 8:44 am
I'm going to give the MUA5 another chance. Bearings are cheap enough and the pilot bearing adapter is only 10 bucks. Can someone point me to a sintered clutch for it? Any heavy duty clutch would work as long as it can hold 400tq with a load.
Johnny V
Has thanked: 2 times
Postby geoffinbc » Fri Apr 21, 2017 3:57 pm
Exedy is about as good as it gets for our applications. Their website might list torque capacity.
geoffinbc
Has thanked: 8 times
Have thanks: 323 times
Postby Johnny V » Sat Apr 22, 2017 8:08 am
I found out that late model Honda Accords also have a 1" shaft and 24t splines. They have 11 1/2" disks as well which is what I needed. There are about a billion clutches to choose from for Accords. I haven't stabbed this motor/trans back in the truck yet so I don't have any updates on what might work. I am taking pictures though so when its finished I can set up a complete thread with details. Also this time I've decided to use(or attempt to use) the Isuzu ECM to run the LS. I'm still going to be using the 6LS ignition box to control the spark but I'm going to try to let the stock ECM handle the fuel. It should also give me all of my gauges back so I can get rid of the GM truck cluster. You can run an LS on just about any OBD2 ECM when you use the MSD 6LS. I have to figure out injector impedance so the drivers can can run them with the right PWM but it should be as simple as splicing the Isuzu harness pigtail to the LS injector harness. The last thing I'll have to do to make it work is make an adapter plate for the Isuzu throttle by wire throttle body to bolt to the LS intake manifold. Again, should be a pretty simple process.
Johnny V
Previous
Return to Drivetrain Mods
Users browsing this forum: No registered users and 5 guests
