HELP! 99 amigo with 00 rodeo trans wiring
Postby Laket14 » Thu Apr 20, 2017 2:25 pm
I have followed this thread to the T but I'm putting the new 4l30e in the 99 amigo wondering if this retrofit will work if anyone has a better walkthrough i would really appreciate it.
viewtopic.php?f=22&t=71505
I get everything wired up and I'm stuck in low no shifting not even manually I'm sure is my fault just if anyone can elaborate or color code this for me i would be good to go....also wondering if this has anything to do with controller...Also before trying this thread i had l 2 3 but no od trans light flashes and check engine light
Laket14
Re: HELP! 99 amigo with 00 rodeo trans wiring
Postby Laket14 » Thu Apr 20, 2017 4:41 pm
Any input?
Laket14
Postby Buster28 » Thu Apr 20, 2017 7:42 pm
The 00 transmission will work properly in the 99 truck if you connect the signals from the PCM to the correct transmission connector pins, recheck your wiring.
02 Rodeo Sport 4X4 3.2L V6
Have thanks: 887 times
Postby Laket14 » Thu Apr 20, 2017 7:54 pm
bought a service man...hopefully tomorrow i can figure this out
Laket14
Postby Laket14 » Fri Apr 21, 2017 10:26 am
Are you sure this ppm can run this trans having the same problem
Laket14
Postby Laket14 » Fri Apr 21, 2017 11:05 am
Do i need to physically ground the tcc sol return?
Laket14
Postby Buster28 » Fri Apr 21, 2017 2:38 pm
In the 90-99 transmission one side of the TCC solenoid was "grounded" to the overdrive section valve body or the main section case, depending on the year of manufacture. Since this "ground" was not reliable the 00-03 transmission connected the TCC solenoid to a PCM external ground using a dedicated conductor. You will need to connect one side of the TCC solenoid coil to a good external ground point. The 99 PCM TCC solenoid control is connected to the other side of the solenoid coil. On the 00-03 transmission the 4 Pin overdrive section connector Pins A(1) and D(3) go to the TCC solenoid coil.
Postby Laket14 » Fri Apr 21, 2017 3:11 pm
Would this cause it to be stuck in first? Tried the winter startup procedure to try and see third and still in low/first..i have come to find out this is a 02 rodeo transmission also if that affects it lmk.
Laket14
Postby Laket14 » Fri Apr 21, 2017 3:15 pm
Also i have both trans pans pulled atm and wondering if anyone had a right up to test solenoids with a multimeter
Laket14
Postby Buster28 » Fri Apr 21, 2017 4:10 pm
Only the shift A and Shift B solenoids are involved with shifting. If the transmission won't shift from Drive 1st or L (Manual 1st) into 2nd gear the A shift solenoid is inoperative. The shift solenoid coil resistance is about 18 ohms.
Postby Laket14 » Fri Apr 21, 2017 4:18 pm
Alright, so I'm not getting anything to my solenoids power wise i checked my ohms 19-21 is what i read i should be reading some kind of voltage when in first/l and 3...also I'm so confused as to why if i wire it up like a 99 ill get l-2-3ish(slippage) no od when none of my shift solenoids are hooked up...bought this for 200 bucks had a half done trans swap i hate working behind people any chance this guy swapped anything from the 99 anyone have a diagram on solenoid location?
Laket14
Postby Buster28 » Fri Apr 21, 2017 4:29 pm
The two shift solenoids (and the band solenoid) share a common +12 Vdc reference. The PCM grounds the solenoid control to energize the solenoid. The 99 transmission is the same as a 00-03 except for the connectors and TCC ground.
Postby Laket14 » Fri Apr 21, 2017 4:44 pm
are the parts holding the solenoid suppose to be stamped with a 99 thinking this is just a mess..might just go pick up a earlier model tranny and call it a day
Laket14
Return to Drivetrain Mods
Users browsing this forum: 1995pickup, Google Adsense [Bot] and 2 guests
