80% Lower
This forum is for the discussion of outdoor activities, other than trail rides
80% Lower
Postby N law » Wed Jul 13, 2016 12:00 pm
I went to a gun show this past weekend and saw where a guy was selling 80% receivers, which are by definition from the ATF, a paperweight. The remaining 20% of the machining can legally be completed by the end user and you will have a non-serialized, no paper trail lower. Seems intriguing, but is certainly not the most affordable route to go. The 80% blank costs just shy of a fully milled and legal (read: sellable) lower receiver plus you had to buy a jig (~$150) plus a drill bit kit (~$45). You'd have about $250 in a "ghost" receiver vs $60 plus background check in a fully transferable receiver.
I came home an did some research and it appears that you can get polymer lowers with a disposable polymer jig for <$100, but you'd still need bits. Some jigs are cheaper but require a drill press to mill everything out.
Has anyone done anything like this before? Pros or cons?
http://www.80percentarms.com
https://www.youtube.com/watch?v=SiHdV5slQps
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
N law
Has thanked: 17 times
Have thanks: 62 times
Re: 80% Lower
Postby Ekholm1997 » Fri Oct 28, 2016 6:04 pm
I too have looked into this. It seems that if you were planning on producing several lowers, it may be worth the cash but, with my limited AR budget, I can only build one at a time..... slowly ;)
1997 Isuzu Rodeo 4WD
3.2L 6VD1, 5-speed , 3" Suspension lift, 1" Body lift, 33X12.50-15 Dick Cepek Mud Countrys, Vision "Soft 8" 15X8 wheels, Superwinch Premium hubs, DuraSolid Mini-Spool, Flowmaster exhaust, AG flood lights, Trail Rated badges, custom painted tow hook.
Build thread http://forum.planetisuzoo.com/viewtopic.php?f=15&t=59551
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
WOW--What a Ride!
"One day, your entire life will flash before your eyes, make sure its worth watching!!"
Ekholm1997
Has thanked: 24 times
Have thanks: 40 times
Re: 80% Lower
Postby N law » Sat Oct 29, 2016 9:45 am
I picked up a blank a while back and have drilled a ton of holes but haven't milled the trigger pocket yet.
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Re: 80% Lower
Postby N law » Wed Mar 15, 2017 3:17 pm
I milled the trigger pocket out last week and finished the lower. I got the parts kit mostly installed, but waiting on the stock to get here to put the last pieces in.
I also picked up a stripped upper to go through the whole process.
I'll post pictures later
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Re: 80% Lower
Postby N law » Wed Mar 15, 2017 9:05 pm
Pics.
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Return to Outdoor Life
